FPV - A long way up
by TehMaxwell | May 25, 2014 | (0) Posted in Projects
Hey all, its been a long time since I have put up an article, been very busy with exams. However a few days ago I finally got the chance to record some FPV footage, after flying FPV several times before. Simply put, FPV is fantastic, just a whole new experience that takes RC to a different level. Anyone who is thinking of trying FPV, I recommend that you take the plunge, because once it bites you, your hooked.
In this article I will be talking about my first experiences with FPV, what I recommend you do on your first flight, good starting equipment and showing you what can be achieved after a few flights. So without further ado, lets get on with it.
Starting Equipment
I am sure many of you will have seen this advertised by Hobbyking before, the Fatshark Teleporter V3 FPV Starter Kit, but I dont think HobbyKing's advertisements do it justice. For anyone who doesnt have a huge budget, but once a good experience out of FPV, there is nothing better on the market at the moment. The kit comes with:
  • Fatshark Teleporter V3 Goggles w/ Built in 5.8GHz Reciever
  • Fatshark 5.8GHz 250mw Video Transmitter
  • Fatshark Pilot HD Camera (Micro SD Card Slot)
  • 2 5.8GHz Whip Antennas
  • Fatshark Battery
All of this equipment works very well together, if you look at Stone Blue Airlines review of the product online, you can get a flavour of what the image is like through the goggles. However there are a few key things about this product that make it the best starter set:
Pilot HD Camera: There are mixed opinions about this online. People say, and it is true, that the camera does not provide true HD video. However from my experience you can see detailed objects just fine through the goggles when flying and the recorded video footage is not that bad quality either (see video further down). What is really great about this camera though is that it provides the ability to record whilst you fly FPV live as well. This function is found in much higher end systems as well, it adds so much more to the package and it is so much fun to re-watch your flight when you get home and see all of the things you missed whilst you were up there. Ultimately this camera makes the package very value for money.
Teleporter V3 Goggles and Video Transmitter: Paired together these two make a winning combo. You see a lot of people online recommending that you upgrade the stock whip antennas to clover leaf ones. This will upgrade your performance a lot, but for people starting out the stock antennas are fine. I have had perfectly clear video when my aircraft was almost out of sight. The image through the goggles is not the best you can find, but for what you pay it does the job, you can't ask for much more than that at £140.
Ultimately this kit works, and it works well. For the price you pay you cannot grumble at all, because it gives you a good experience. Plus, if you buy this and you want to get further range, then you can just swap out the video transmitter, get a better pair of goggles. The set can grow with you.
First Flight
I wont rant on about this, as there are great tutorials online about how to get a good first flight in (IBCrazy's are great!). But there are a few key tips I would recommend.
  • If you can get someone to buddy lead you then great, take that opportunity. On the first flight it releaves the stress of loosing your plane, so you can get to grips with and enjoy the experience of flying FPV.
  • If you have a buddy lead, then I recommend you don't take off or land the plane, let the other person do it. This helps to make sure you dont loose your gear to a crash after only flying once. If you are alone, do not take the goggles off to land, this can only end in disaster, land with the goggles on. I recommend if you have to do this, then fly in a large open space so you can land anywhere and still find the plane.
  • When you are in the air, try and fly towards large landmarks that you have predefined before the flight. That way you will always know where you are in the air. I would recommend you do not try and think about where the plane is in relation to you on the ground, think about it as a seperate entity that you are sat on yourself.
  • Make sure you enjoy it! :D
If you follow these simple tips, there is not much that can go wrong in terms of your flying, only an electronics failure can occur.
So what can be achieved after a few flights?
As I said previously, this video was only taken a few days ago. This is probably around my seventh or eighth FPV flight and I have already managed to get to grips with navigation in the air and landing. I would almost say that flying FPV is easier than Line of Sight, as there are no problems with orientation.
So without futher waffleing, here is my recorded video, please bare in mind that this has been edited down from about 10 minutes worth of FPV flight. Enjoy!
Ultimately I would say FPV is a fantastic piece of technology that everyone in RC needs to try at least once, as if you enjoy it can open up a whole new world for you.
Thanks for reading this incredibly long article!
Happy Landings,
TehMaxwell
1959cutter on June 27, 2014
i just flew my first fpv a few days ago,and I get dis-oriented by the sound of the plane(its not where it sounds like it is) I fly alone in a big field and agree,dont take them off (goggles)once you put them on,you will crash!
im hooked now!
the deal I got was foxtech FPV combo with goggles,Tx Rx and outside camera for watching whutz up without removing the goggles.
I got the whole plug and play system for $560.00 the same price for just fatshark without plug and play!
TehMaxwell on June 28, 2014
Yes FPV really does get you hooked doesn't it! I jump at the chance to fly whenever I can. At the moment my FPV Wing is grounded as I am upgrading the set-up to hopefully double or triple my flight times. Should open up a lot more things for me!
srfnmnk on June 30, 2014
I am working on getting my FPV off the ground :P but I don't want to spend two or three hundred dollars for something I know I am just going to want to upgrade. I would rather pay the 700 or so now and get a system that I love. Second, and perhaps most importantly, I am very curious about the ranges by mW. I know there is a wide range of interference and what not but a good baseline for distance by system would be nice, does anyone know about where we might find something like that?
Thanks for the post, great article!
Battershell on June 27, 2014
Not sure how much you paid for the camera but hopefully very little. The white balance is terrible. Mobius or Gopro is way better and you can FPV through them as well while recording also. I noticed you submitted this a month ago and it finally hit the site today. Wow! Flitetest guys must be very busy.
The camera comes with the kit and I don't think you can buy it separately, I agree that the white balance is terrible and it struggles greatly with a change in light level. Definitely worth an upgrade, but at least it does the job for now.
Yeah they must be busy, although with going to Europe and everything you can see why! Thanks for reading! :D
TehMaxwell on July 1, 2014
Sounds like the Ready Made RC package is what you are looking for, I haven't used it personally but I have only heard good things about it. Only thing that it lacks isa goggles, so if you are really set on goggles then maybe look at one of the higher end Fatshark packages.
FPV - A long way up
