Hi Guys
I recently built this Fan powered RC car with the help of my metal work techer at school. It runs a ParkZone 2200Kv motor (Origionally from my friends Stryker) with an E-flite ESC (don't know which one sorry) I used Tyres from a Tamiya Midnight pumpkin. The base is aluminim with an aluminium motor mount riveted onto it. these pics are a bit outdated since i turned the motor around and put the servo in a different position. one thing i am having trouble with is that when ever i go to full throttle it start spinning around like a yoyo. can anyone give me a suggestion on how to fix this?
The steering wheels have a bit too much camber (working on that)
The back axel attachment system (credit to my metalwork teacher)
If it is always spinning off to the same side you can try to off set the motor in the opposite direction using small metal washers.
Maybe do an experiment and try moving the motor mount forward and then try it in the back. You'll just have to drill a few extra holes.
https://cashcashcars.com/areas-served/junk-car-removals-los-angeles-ca/
