End servo wire confusion
by TommyGunn | October 17, 2013 | (24) Posted in How To
I don't know about you guys but.. Everything around me can be very messy.
messy-office-03
But when it comes to my electronic parts I like to keep everything  neat and tidy.
Before
IMG_6550
After
IMG_6595
When it comes to servo wires I have tried making labels with tape and tags but they smear/fall off after time. I also have used the hobby king shrink tubing labels but then I have to order them wait two months .. cut it and heat shrink it too much work and time.
servoleadmarker-main
And if you try and put them on the Plug It is way too tight to fit all your servo plugs into your receiver.
funny-pictures-weird-passenger-D5P
Here is an example for planes you made the Flitetest spitfire you installed the rudder and elevator servo you shake the wire thru the body now which wire is which?
Another example is you have to rewire your quad for some reason or other... After you zipped tied everything nice and neat you now have to cut the zip ties to see which wires goes where and then re-zip tie everything again.
indexIt's no use crying about it!
I don't know why but the second time around it is never as good or neat as the first time. Does this happen to you? Let's take a poll on this one.
But and today only!  I am going to offer you a free tip! Yes absolutely free! and if you read now you there will be no shipping! operators are standing by!
The video
Here is what you will need:
A white crayon or any light color crayon or wax pencil you can use black if you are a masochist .
A Little jeweler screw driver or x acto knife.
a credit card.
What to do:
Step 1
Get a servo Plug and lay it flat on a table.
Step 2
With you tool of choice begin scratching or etching the letter A
Do this on both ends and both sides if you wish.
Sequence 01.Still001
Step 3
final rub the crayon over the etched A a couple of times.
2
Step 4
Wipe excess with finger now etching should visible.
rub
Step 5
YOUR DONE!
4
You now have a permanent aliron servo wire ID!
Now proceed with the other server leads for E R T AX1 for aux.
You can do the same for quads motors esc M1, M2, M3, M4
Step 6
I go shopping!
IMG_8638
So the next time you have to switch some plugs around you will know exactly what wire is what!  And you will not have to cut zip ties to trace wires. Or have to use a transmitter to see what servo/motor is what.
Even if you don't have a crayon you can still read the etchings.
As always if you like it visit my other links.
I hope you guys like this tip!
and don't forget to subscribe and like!
blog: www.tommy-gunn.com  videos: www.youtube.com/tommygunnfilms
Now on twitter: #tommygunn2 come say hi!
Remember if you not hitting that 5th star your not flying ;)
Have fun flying! Yaba daba doo!
ff1
chaydock on October 17, 2013
Very cool. Thanks for the awesome tip!
rslegge on October 17, 2013
Labeling the connectors is a great idea. You can also eliminate some wire clutter by removing the red and black/brown wires from all the Rx to FC connectors except one. The same can be done for the leads from your multicopter's ESCs, the red and black/brown can be removed except for the one that powers the FC.
TommyGunn on October 17, 2013
You got ten seconds.... should you cut the black wire or the brown wire..? tick toc..Booom! :)
Yep that is good Idea because on a quad all you need is motor one to power up FC.
But I some times switch esc's so I did not bother doing it.
tramsgar on October 17, 2013
Good tip! For a multicopter, you could also use stuff that use a serial protocol and only need one wire. For planes, still a good tip =).
RoyBro on October 17, 2013
The same can be achieved using either Sharpie silver, or Sharpie oil based paint fine point pens. They are permanent, opaque, and are visible on light and dark backgrounds.
TommyGunn on October 18, 2013
Yes and no to that... The servo plug is made of petroleum base non pores plastic and the sharpie will wear off after time. I have used silver sharpies on other plastic things that have worn off or smudged. That being said it will stay on forever if you etch the plug first with an sharp object it take less than a minute to do it. You don't even need the wax pen or crayon etching is free fast and easy.
Besides... How else would I a get a picture an elephant in the story?
JustinTime on October 18, 2013
The only downside I see to your method compared to the sharpie is that once you take out the servo, or the extension, and use it somewhere else you have the marking that may not match whereas with the sharpie you can wipe it clean.
No don't get me wrong I like The sharpie Idea. but in my case i want a permanent set of servo wires AETE and AUX. I can re-use those wires in another other system . unless you are talking about motors? what wires would you swap?
Gree on October 19, 2013
Simple idea and a good one! Thanks
TommyGunn on October 19, 2013
Thanks!
