TNF-F14 DTFB Pusher with swinging wings
by 81zapper | September 7, 2015 | (14) Posted in Projects
I have found a new passion now that I found flitetest. I love to build models and have an obsession with airplanes. I have always had an interest in rc but never could see spending the money and crashing. Now with DTFB a good crash is a good lesson on aerodynamics. I love to challenge myself so I decided to make an f-14 with retractable wings. It is a pusher version as my Cheap 60 mm EDF was just too weak to handle the plane . The following article is about the build of my TNF (Toss and Fly) f-14 , with free pdf and cad drawings if any one is interested in trying .
All the parts were ordered from www.GEARBEST.com. I am not affiliated with gearbest it's just another option that I found out there . Links for the parts will be at the end of the article. Their prices are comparable and shipping was fast.
The main challenge was  the wing and how to get them to move. After several weeks of planning and several prototypes , I think i managed to get a decent way of moving them. At first I used a slow moving servo (Turnigy TSS-9S) but it didn't have enough torque to move the wings during flight . I installed a regular 9 gram servo and it works fibe just not scale looking during movement. Flight characteristics did not change very  much if at all
The video below shows the slow servo and the movement
WING BUILD
So lets start with how I did the wing movement.
First off here are the parts that I used.
3/16 rivet , 1/8 hobby plywood ,3/16 hobby plywood ,4-40 x 1.5 screws with nuts and flat washers  small eye bolt and pushrod material plus a  .190 wood dowel
I took apart the rivet and opened up the sleeve just enough to allow the screw to fit in and spin .
  this is the swivel point
BELOW ARE THE PARTS USED FOR THE MAIN FUSE SWIVEL POINT
Here is the fuse with the wood   ready for glueing . Note that I removed the paper and foam to allow the ply to sit almost flush
The wing is assembled with the 1/8 ply . The ply is glued directly to the foamboard on both sides .This will allow the wood to rub and not the foam when the wing swings.I also installed a small dowel for the servo connection point.  (see below)
Above is the wing ready for glueing the servo connecting point
I used some push rod material and a small eye bolt  just large enough to allow for the dowel to go through.
I soldered the eye bolt to the rod
The most dificult part was finding away to allow a servo to move the wings. I came up with this design after serveral different attempts. I glued a popsicle stick to a round servo arm and drilled several holes into the popsicle stick  to allow for some adjustments
Here's a closer look at the wing mechanics
   ELEVON
The elevon assembly was another smaller challange . I used a dowl rod with a straw I borrowed from Wendy's and a popsicle stick . I removed some foam using the glue gun tip to recess the rod.
I also made a slit where the posicle stick goes for clearance and this also prevents the rod from moving in and out causing the elevon to jam (see end of maiden flight to see result of a jammed elevon)
Once these two items were solved everything else was pretty basic using Flitetest methods
This is the fuse ready for assembly less the poster board . It is best to assemble the wing and the elevon system to the fuse before glueing on the sides.
Once the wings and elevons are installed it is now time to put on the sides and add the servos for the elevons . The poster board can then be put on the sides once all your wiring is fed through.
The fuse top and canopy are next to be assembled
Electronics installed.Almost ready for maiden. I usually put the esc underneath at the back to get maximum cooling and run a long extention for the battery which I place at the front.  A 2200 mah battery gave me the best cg when placed at the front
 LETS GO FLYING
Wings in closed position
 Wings in opened position
 Here are some links for the parts I used
SPECS:
Motor  Emax  2215/20
ESC 40 amp
Prop 9x 5
9 gram Servos
Weight 488 gr  not including battery battery
 Wing span open  -36"
 Wing span closed - 26"
 Length -37"
 Please note that I am not a great Cad person ,so my plans are not quite perfect. There may be some minor adjustments you will need to do for a perfect fit , but over all they should be pretty close.
Below is the video of the maiden flight , along with pilot error then a nice roll  and crash, when elevon got jammed , hopefully when time allows I can get a better video
 PDF PLANS ARE AVAILABLE HERE
wing fuse tiled
fuse sides tiled
fuse top tiled
Stabilzers and elevons tiled
Supplies
Or Full plan in .dwg
full plans .dwg format
Yogenh on September 13, 2015
It looks great but hard to tell how well it flying.
81zapper on September 14, 2015
Ya sorry about the video. Only have an iPad for filming. I was actually quite surprised myself how well and easy she flew as I have only been flying a couple of years now and only flitetest stuff or my own designs . If I get a chance I'd like to fly again with closer flights to camera
Damig on September 16, 2015
Great Job!!!!! You were reading my mind... Super notes. I appreciate ya Sir. Scott
81zapper on September 16, 2015
Thanks. let me know if you build one and we can compare notes
jeeps on November 9, 2015
Really cool swept back wings always look so cool. It would be neat to see a F-111 or B-1 in this style. I love it when these foam board planes get more detailed.
HilldaFlyer on September 14, 2015
I like the complicated build with simple items. Good job - looking forward to the next video.
Thanks for the comment . I like keep things as simple as possible for myself
I just wanted to try and see if I could do it. Its far from perfect and Im sure
There are lots of better ideas out there but hèck it was fun and it works not too bad
Maikara on October 10, 2015
Amazing build. I would love to try this. Way above my skill level but still would be tons of fun to try.
NoUsername on September 13, 2015
Great looking plane. You did a fine job in your photo's also.
Thank you. It's not a great looker but it looks real nice when it's in the air
