Flite Test community member 'Rasterize' showed us how to apply custom sticker designs to your foam board airframe! Steven’s designs are amazing and can be seen on the Baby Brits and Baby Barons from our WWI Gotha Bomber episode.
To start, create and print out your graphics. Tiled plans make a great cookie cutter template for creating designs. It’s recommended to print on 24lb bond paper or lighter, and use 11” x 17” paper to reduce the amount of tiling needed.
Cut out the stabilizer designs. Leave paper around one and use a razorblade or scissors to cut out the other.
Remove the paper from both sides of the foam. Use Super 3M 77 Spray to glue the piece with the extra paper around the edges to your foam board. Then cut out the design, foam and all!
Take the other stabilizer design and make sure it lines up correctly with the design on the other side of the foam. Hold down one side, peel the skin back and use the Super 3M 77 spray to glue it down. Once it’s glued, peel up the other side of the skin and use the spray to glue down the other side.
Thanks to Steven (Rasterize) for sharing his tips to apply plane skins and for sharing his incredible designs!
Look for the download & donation page for Steve and his skin designs
COMING SOON!
In the meantime, let us know what designs you'd like to see!
Have tips for applying plane skins or cool designs? Share them with us!
I'm really looking forward to this!
Putting in an order for the SE5 but I
REALLY digg that Pietenpol Air Camper
Josh built in the video blog! Hope that one
goes to production next!!
Is there any schedule when the plans are able to be downloaded (could not find the download&donation page)
Thanks for this great work and sharing
Will your download and donation page be available soon?
I just wanted to mention an alternative to peeled DTFB; one of the vendors at Flite Fest, Mike Spring, provides some really good materials at http://www.modelplanefoam.com. I have a sample of his stuff here on my desk. It's the same thickness as DTFB, but uncovered... and is a good deal stiffer than peeled foamboard. He also has some really nice kits for sale at onesheetkits.us. Shameless plug, yes, but combining these cool skins with the other foam might be a better solution than DTFB. Cheers!
http://flitetest.com/articles/foam-board-that-looks-great
FT-Skins Article
Instructions on how to make the skins,
or
The page with the skins.
My airplanes need the upgrade to fly at Flitetest east.
Thanks
