Hello all of the people in the world that happen to be reading this!
So there are pretty much hundreds of videos on youtube on how to make a servo rotate continuously, but they pretty much all suck. Either they don't speak English or they record with a potato and make no sense.
So the first step is to take the bad servo appart.
Then you are going to remove the gears and pop out the potentiometer.
De-solder the wires off the potentiometer
Take appart the good servo and locate the potentiometer
De-solder the wires off of the potentiometer but keep the good servo's potentiometer in the servo
Solder the wires coming from the good servo's board to the bad servos potentiometer you removed earlier
Remove that tab from the top gear of the good servo
Put it all back together, set it neutral and bam! You have a continuous rotation servo!
Also I picked up a Zoom H1 microphone so the audio is better, if you want a video on that a bit I could do that also.
Let me know if you want to see a rover video. I hope you found this useful or a good refrence.
5*
http://www.youtube.com/watch?v=r536e6ap80Q
