so i did not make a video "HOW TO" because i was not sure from the final product,but it turn to work pretty well,so is really easy to do,no solder are necessary,I just push down the potentiometer and cut of the stopper from the gear so the servo will turn 360°,then thake a few rc car gear and bearing laying around,and that's it!!!
I tried to turn a servo into a 360degree servo but I gave up because of the complexity of it. Well, I actually did make a 360degree servo that was really easy to make but it moved too fast and had no power. There was no way it could work for FPV.
If you want make one who goes back to center,you have to make first a 180° with resistance hack and then cut one of the 2 stopper in the servo top! Maybe is not clear,so i'll make a video to show how I did,,
