Simple Transmitter Throttle Safety
by HoriAkuma | September 27, 2012 | (22) Posted in Tips
Ever accidentally nudge your throttle stick while working on or setting up your planes? Prevent accidents with this simple and cheap throttle safety.
All you need is a few rubberbands...
[broken image - invalid source]
Connect them together,
Connect them to the handle on the back of your transmitter,
...and wrap around the bottom to the front, looping it around your throttle stick. Stays safe, but slips right off when you are ready to fly...
jetpackninja on September 28, 2012
Awesome-
and check my article if you would like to make a more permanent version. Good job and continue to play safely!
http://flitetest.com/articles/Ninja_Quick_Safety_Tip_Throttle_Safety
Mirabile Visu on September 30, 2012
What a superb idea. I'll pass it around our flying club, as it's too good a safety tip not to spread around.
Thank you very, very much.
Trevor
htomnlinda on September 30, 2012
What a great idea, I'm on a blood thinner and can't afford any cuts of any kind. Thanks !!!!
Trondareo on September 28, 2012
Another super simple solution to a practical problem. Keep the simple solutions coming!
iLoveRC on September 27, 2012
actually, not a bad idea, let me try that!
Benn Gunn on September 28, 2012
Very good idea... i have put the fear of god in myself by hitting the throttle by mistake
Nonamerc on September 28, 2012
I rather use my programmed throttle cut but this should work just fine for non-programmable radios :) 4 stars
jayman72 on September 29, 2012
There are times when the simplest solution is often the best and this is it. I am now using this and love it! With spinning blades and props you cant be too careful. Even with throttle cut better to have two safety mechs.
andybris on September 27, 2012
Dude, Idea is full of simple awesomeness, defiantly stops prop rash.
HoriAkuma on September 29, 2012
Thanks a lot, everyone!!!
