Hi guys!
Just wanted to share with you a scratch built delta wing that I designed. This is easily my favorite plane to fly and is very easy to build. It has a 30 inch wingspan, 11 inch root chord, 9 inch tip chord (including 2 inches of elevon), and 11 inches of sweep. I made it with a KFM2 airfoil to add some lift. The plane, aside form the KFM, is made from a single sheet of dollar tree foamboard.
Motor: 1300 kV blue wonder from HeadsUpRC
Prop: 8x4
ESC: 18A
Receiver: Orange Rx
Battery: 1300 mAh 11.1V 3S lipo
Servos: T-Pro 9 gram
Let me know what you think! - Nick
I am gonna try to knock one out this weekend.
I really like this plane. Super easy to build and fly. It is quite resistant too. I have flown it with a 2200 mah and it worked!
Thanks.
Kv - 3000rpm/v
Load [no prop]: 1.2a / 7.4v @ 21500rpm (0g thrust)
Load [7x4 prop]: 21A / 7.4v @ 8800rpm (380g thrust)
Load [8x3.8 prop]: 22A / 7.4v @ 8200rpm (430g thrust)
The specs from HK
I had both, but the 1300 kv broke the same day I put on the FT Flyer.
I wonder if this is OK, and if it is not, I would like to know what I can do to fix this situation. should i bring the motor forward?
below are the parts I have used.
D2826-6 2200kv Outrunner Motor - 50 grams - mounted 28.5 cm from nose
1600mAh 3s battery -122 grams
30 amp esc - 22 grams
