5.8G FPV Setup Part 2 LC Filter & Regulatos
by jamiedco | June 24, 2013 | (5) Posted in How To
this is the video part of the series
now this is the circuit diagram
this is the strip board you will need to cut for a lc filter
this is the parts list
LC Filter Parts List
1 x ferrite ring (off esc)
1 x 470uf 25v electrostatic capacitor
1 x led (colour is ur choice)
1 x 470ohm or 1k resistor
also some wire to hook up the parts and wind the coil
LC Filter Regulator Parts List
1 x lm7809 (or equivalent )
1 x 10uf capacitor (input side )
1 x 220uf capacitor (for output side )
here are my builds of the lc filter and the regulator
ALSO CHECK OUT MY SITE FOR MORE STUFF
www.jamiedco.com
danallen82 on June 26, 2013
Thanks! What gauge wire and roughly the amount of winds did you use on the coil?
jamiedco on June 26, 2013
i believe its 30awg and i wound 3 layers
lougedo on July 25, 2013
where did you get the 30awg wire please?
jamiedco on July 25, 2013
http://www.sunsky-online.com/product/default!view.do?subject.id=251467
Thanks, I will use this for my next upgrade!
Are you using those inline, so first the filter then the regulators?
Do you think this would be helpful on the 5v BEC, directly inline after the BEC?
the bec does not always put out clean power so put a filter inline after the bec and you will be in clear
Auxiliarypower on June 25, 2013
Very nice sir thank you very much for sharing this with us.
