Cannister Smoke Bombs from Phantom Fireworks.
The very complicated holder. A paper tube with a slit in it and some velcro straps. The metal foil in the back is there to keep the smoke from eating up the foam.
Held in place by another velcro strap fastned to the plane.
Up in the air.
The specified burn time on the smoke bombs were 90 seconds. That was pretty far from the truth.
The graceful figure of David in full gallop is an astounding sight.
Reload time.
The orange looked the best by far.
Our faces as the orange smoke came on.
About 10 seconds later when the smoke ran out.
Make a smoke system using a hot wire(contained in a cylinder exiting the bottom of the plane), smoke oil(I can get it at the local hobby shop), a small pump,(???) a small tank,(also from hobby shop or hobby king) and a small brushed esc(hobby king ect). Have the smoke pump spray the oil onto the hot wire coils contained in a tube, the oil would evaporate into smoke and exit the bottom of the tube in a nice thick plume. That way you would be able to make smoke we can all see better then a smoke bomb.
Smoke systems have always been the province of large gas planes it would be nice to see a smaller setup for medium and small sized electrics. That we can all build and afford. Then we can show the gas guys that there is nothing electric planes can't do.
Now cue the cheesy A Team theme and get to the basement.
And as always have fun
Jonathan
I know David said he was going to re-do the rocket plane later. Using sparklers to fuel it would give you more control over just how powerful it is. (You can use more than 20.)
No, the AMA has no place here, and I'm glad for it. It would just squash all the fun and force these guys to fly in circles all day long with small planes.
Cheers
"Kraut Rob"
This should be for adults not your kids who love to burn things down, be responsible with all lethal chemicals.
VikingPilot
I found these http://rocketfireworks.ca/smokeemit5pk.html hopefully the guys will see this, up to 5 minute burn time and only weigh 18 grams, they also look to burn pretty vibrant colours, I'll definitely try them out!
