Rotor Bones Straight 13-370 BUILD
by FliteTest | May 7, 2013 | (17) Posted in How To
Motor mount and landing gear for multirotors. Supports motors up to 370 size (45g) and 8X4.5 props.
These are the assembly instructions for the Rotor Bones Straight 13-370 motor mount and landing gear. You can purchase this product HERE.
The Rotor Bones Straight 13-370 motor mount and landing gear package includes two complete units. They are laser-cut from acetal resin, an engineering thermoplastic used in precision parts requiring high stiffness, low friction and excellent dimensional stability.
These were designed around common 1/2" (13mm) square wood dowel.
Pop out all the pieces.
Keep these pieces...
Mark your holes with a pen or pencil. Use a 1/8" drill bit... and make sure you drill them straight!
Snap in the motor mount and tab into one of the side plates. Everything is symetrical, so it doesn't matter which side plate you use. You can install the motor mount in the upper or lower slot, depending on the type of motor you are using and how high you want it mounted.
Insert the center strut.
Install the other side plate. Make sure to slide the bottom tab first.
Now slide it on to your boom.
Install the screws and locknuts.
Done!
Here you can see the two different options for motor hieght.
I truly hope you enjoy your Rotor Bones parts!
Thanks,
Chad
Hasersys on May 8, 2013
these are sick
longbikez on May 8, 2013
these look to be a sweet solution.
colorex on May 8, 2013
What about the guide for the yaw mech?
Splatwillicrash on May 9, 2013
It is up, they are QUICK around here....
liveyourdreamsRC on May 8, 2013
Cool looking, Easy, fast build... Every need has been fulfilled!!
Auxiliarypower on May 8, 2013
Chad take my money damn it!
I had to almost wrestle money into his hands on my last order..... ;-)
Mirabile Visu on May 9, 2013
I'd love to buy these, but the postage to England is more than the price of the kit. Surely they can fit this in an envelope, and send it airmail, and we can find our own wooden copter arms?
Trevor
Enrico on May 9, 2013
that Sir sounds like a plan to me. :-)
What do you guys say?
would you consider making a few Britons happy by saving them loads in shipping costs and allowing them access to your absolutely brilliant product.
Enrico
MusicmanOBS on May 15, 2013
Hey have you guys gone ahead and bought these? if not could I tag along join this payment? Im based in the UK but I dont particularly want to spend a fortune on shipping fees :)
simba42 on June 10, 2013
I would be up for a couple of sets too.. I'm in Milton Keynes
serial0l0 on May 9, 2013
Do you guys think these would work with the HK x900 tri frame? I need some new mounts...
Corsair2014 on May 10, 2013
these are so very awesome!!! now we need a spiderquad frame(:
and some delrin versions of the anycopter frame!(:
Splatwillicrash on May 19, 2013
That would be nice indeed.
Camocarp on May 11, 2013
I'm very glad to see your now getting more involved with the "Multi Rotor" flying platform, these are my favorites. Keep the information coming guy's.
I really like to watch David build these and I think the way you explain things is very helpful.
Also although I don't own an RC Airplane, I like to watch J B build them; very easy to follow descriptions. Chad these Rotor Bones are top rate mate; and little Josh is so funny :)
Top of the class guy's. Keep it coming please.
WingNutz on May 11, 2013
Im Brand new to the hobby and based on Flite Test's Can Do Instructions, I wish to try to build a tri copter
Can anyone point me in the direction of what motors mount on to these? I've searched Hobby King and others for a 13-370 and a 370 motor but cant find anything that looks remotely close to those shown in the videos here...
Also can someone point me in the direction of the board David is using on his copter
there is a complete build list but they may be backordered. They also may have some over at lazer Toys. or Value Hobby.
BackyardRC on May 11, 2013
Great work guys. I just bought a set to build a new quadcopter... small suggestion: Please design a set that is twice the hight (or more) to build taller quads. I have a few larger camera's I'd like to hang. If you build it I'd totally buy the taller set too.
+1
Ryanb on June 13, 2013
just a quick question, do you lot have a PDF for these???
BadHabits on June 23, 2013
They look GR8, can't wait....;-)
Mark
mark.turner@yahoo.com
Sewyboowy on October 31, 2013
heres the PDF. http://www.stonekap.net/ftplans/Rotor%20Bones%20Straight%2013-370%20%5B0422%5D.pdf Theres no motor mount piece though, weird
jackthursby on November 19, 2013
did you ever get the full PDF?
hursto75 on February 8, 2014
Not seeing the motor mount? Does anyone have the motor mount plans?
Thanks,
Random_rc on June 14, 2014
Would you be able to mount a dt750/dt700 on these mounts
Yasas Pasindu on June 12, 2017
does anyone have a plane to that motor plate?? :)
