ReadyMadeRC - Showcase
by FliteTest | September 10, 2014 | (8) Posted in News
We had a chance to fly some of ReadyMadeRC's latest airplanes and use the FPV Packaged setup to watch some of our flight on an external monitor.
The Anaconda was setup for FPV and we did some formation flying with the Lunar Eclipse
More details about the RMRC Anaconda - KIT available at: www.ReadyMadeRC.com
SPECS
  • Wingspan: 2,060mm
  • Wing Area: Approx. 4900cm2
  • Length: 1,410mm
  • Motor: 35-48 800-1000kv Brusless outrunner
  • Propeller: 13x6.5 E or 14x5.5 E (Not included)
  • ESC:  60-80A ESC with switch mode BEC
  • Servos: 3x 30g and 2x 17g Metal Gear Digital
  • Recommneded Flap servos: HS-81/HS-85
  • Battery: Li-Po 4s 5,000mAH - 20,000mAH (Additional nose weight needed with smaller batteries)
  • Center of Gravity: 1/3 of wing from leading edge at the main spar
  • Approximate flight duration: 45 minutes to over an hour depending on configuration
  • Fuselage dimensions (Inside): L 66cm (26.5") x  W 15cm (6") x H 8cm (3") Maximum measurements
The "mouth" comfortably holds a GoPro but is able to be modified for any type of FPV camera.
ReadyMadeRC Quick Start FPV Package (Monitor, Transmitter, and components)
Here's a list of just some of the items included in this package:
  • ImmersionRC 5.8GHz 600mW Transmitter
  • ImmersionRC 5.8GHz Uno Receiver
  • Spironet Omni Circular Polarized Antenna Set
  • RMRC 7" Monitor
We had to have something for the Anaconda to hunt in the air, so we also threw up a Lunar Eclipse.
Learn more about the RMRC Lunar Eclipse - PNP (with Motor, ESC, and Servos)
SPECS
  • Wingspan:  1240MM
  • Length: 960MM
  • Wing Area: 21dm sq (Mainwing Area)
  • Motor: Brushless outrunner motor 2820-3540, 900-1000kv
  • Prop: 10x7E
  • ESC:  20-30A
  • Servos: 9g
  • Battery: Li-Po 3s 2200mAH - 3300mAH
  • Center of Gravity: 70-80mm from leading edge of wing root
We'd like to thank ReadyMadeRC for the opportunity to try out these great airplanes.  Let us know if you'd like to see more on these airplanes in the future!
Be sure to check out www.ReadyMadeRC.com for details about anything you saw in this episode!
kokopellimusic on September 11, 2014
Nice planes. I was surprised at the amount of "Jello" effect the drone had on the camera. Especially with the prop in the rear. What was causing all that vibration?
Davo6 on September 11, 2014
I reckon retractables on the Lunar would look good.
Flynn on September 11, 2014
Hey Guys, Which OSD was that? Great Cam work Alex! Great Episode
Adrianm1972 on September 23, 2014
I hope when you do the full review on the Anaconda you fly it more as it was intended. Its a long range FPV platform, should have a good flight controller like an Eagletree Vector, 1.3g video, a go pro on a gimbal and a separate FPV camera.
PropSpinner on September 11, 2014
Good job guys! I wouldn't mind an Anaconda just for sport flying.
lark95 on September 10, 2014
wow, love the anaconda!
Digital Wolf on September 11, 2014
Awesome! Very cool airplanes!
Cmflywild on September 11, 2014
This airplane is amusing to me. You mentioned in your video that it looks like a military drone, that's because it is almost identical to the RQ-7B Shadow 200 TUAS manufactured by AAI/Textron Systems. This is the platform that I fly everyday at work. The funny thing is, the real Shadow 200 does not fly very well manually, of course it is also a 20' wing span and weighs 400 lbs. Also, the fact that "it does a coordinated turn" is NOT why the military likes it so much. I'm not trying to hate, I just wanted to bring some facts to the table.
Defog on September 10, 2014
Oh Santa...
casehatter on September 11, 2014
Kinda seemed like a Professional Plane in the hands of babes and the timing with the FAA well I don't know just make sure that everyone joins in with the AMA's complaint with the FAA's interpretation of the rules, or there will be no FPV or Flite Test so get you say in to the FAA and we need to police our own as far as rule breakers so it doesn't hurt everyone. So use common sense and fly safe. The Anaconda is great as far as what she was built for.. Love Ready Made and Hobby Wireless..!!
