Lost Aircraft Alarm
by mxclouti | March 30, 2014 | (6) Posted in Projects
Here's how to make a lost aircraft alarm out of a cheap door alarm and a brushed ESC.
You'll need:
- a cheap 100 db door alarm from the dollar store. It runs on 4.5V (3 X 1.5V button cells)
- a brushed ESC to trigger on/off the alarm. I'm using an old GWS ICS50 2A ESC.
- foam board to make a sound box for the piezoelectric plate
It weighs about 16g.
See the wiring diagram below.
Alarm in action:
ashtodust2000 on April 7, 2014
Brushed esc cost more than buying a lost plane alarm.
mxclouti on April 7, 2014
Yes, maybe, but I have 10 of them here !! So it's free for me !
I used to have an online store ... years and years ago !
A lost airplane alarm is not as loud as mine (I've tried those).
Mine is around 100-110 db, that's loud, really loud !!!
rcspaceflight on April 7, 2014
If the door alarm runs off of 5volts, then couldn't you use a servo as the trigger? You would just remove the servo chip and then solder the alarm to the motor leads of the servo. Then you would have a cheap alarm. Especially if you have a stripped out servo.
rockets4kids on April 8, 2014
These buzzers have been used for quite some time in the model rocketry community for the same purpose. They are easily controlled with a transistor. I have never used them with servo-signals before, but you should be able to turn them on and off using a low pass filter.
I'll see if I can put something together this evening.
c.sitas on April 9, 2014
Hey,guys just search out the black box on flite test. I can vouch for this unit. I've made a bunch of them . Maybe a very slight bit of heavy but huge on the sound and long as well. I guess I'm stuck on this . I've mentioned this on a couple other sites but,,, they can't seem to get beyond the little lost p[lane things they sell on ebay. Ya they work similar, but not the same. I just fly with a new sense of recovery now. "I fly over a lot of heavy forest. A down plane now is no big deal , less maybe it might take a chain saw. Hee Hee .I love this foam flying.
Lost Aircraft Alarm
