GPS Protector
by ArchiCopters | December 11, 2014 | (5) Posted in How To
Usually, the GPS antenna is one of the most exposed and vulnerable parts of our multirotor. In this video I explain step by step how to do, with cheap materials, a protector for our GPS antenna.
Materials:
-A rigid plastic glass
-Aluminium adhesive tape.
-Doublesided tape
 This is a very easy tutorial about what I have done.
First thing you have to do is find a good plastic glass where your GPS fits well.
Measure and mark the height at which you are going to cut. 2cm is enought.
After triyng other methods to cut it, I finally use the Dremel.
Protect your glass with tape to protect it if you fail cutting.
Do a slot to introduce the cable.
The aluminum tape is to isolate the noise of other electronic components, which can cause the errors. It works like a Faraday shield. It should be welded to the negative of what you want to isolate ... but for now is a test. Depending on the metal (copper, aluminum, ...) isolates one or other frequencies.
Draw the bottom diameter and the inside weight with a compass and then mark some radious to cut them to achive the cilindrical shape.
Fix you GPS with doublesided tape.
Now, if a crash happens... the glass will receive the hit, protecting your GPS antenna.
That is all! Good flights!!
I hope you like it! I will give you more tips on my YouTube Channel.  ;)
tsbanking on December 14, 2014
Yep, now its well protected...
Gsimpson2g on December 15, 2014
Nice idea! Good call with the shielding too. I have been running into issues with my Midland XTC camera giving off lots of noise that kills my GPS signal.
ArchiCopters on January 22, 2015
Thanks! I hope it have helped you with the noise. :D
stereodreieck on December 26, 2014
One of the best (small) articles all time. 2Thumbs up
Thank you stereodreieck! I have just subscribed to your Youtube Channel!
GPS Protector
