A Vampire Mk6 modified with a real working EDF afterburner! Powered with butane and ignited with parts from a stun gun, David attempts to fly this EPO foam RC airplane with real flames shooting out of the exhaust tube!
Durafly D.H.100 Vampire Mk6 EDF Jet RC airplane is designed with a faux EDF Jet exhaust so David moved some internal parts around and added a butane fueled jet exhaust.
The fuel is despensed in a circle over the flame holder and creates the afterburner.
A full write will be available soon detailing everything that went into this custom afterburner setup.
This is our first "Don't Try This At Home" episodes, so please be safe and don't try this.
If you are interested in a safe alternative to creating an afterburner look to your RC airplane, check out our LED Afterburners Episode!
The flame did melt some of the foam on this EPO foam RC airplane and melted the servo a little, but the thrust angle worked great and the butane afterburner added 15% thrust!
There are more photos in the forum post, be sure to check those out and join in with the discussion there!
Click Here to check out the forum post.
Check out the extended episode below, detailing more of the work involved in creating an EDF Afterburner on a Vampire Mk6.
Thanks for watching!
RC Airplane shown in this episode:
Durafly D.H.100 Vampire Mk6 EDF Jet 1100mm (ARF)
That being said - I applaud you guys for making the video age-restricted on the YouTube; However, the video is not restricted when viewed here on this page. Maybe consider linking to YouTube instead embedding it here?
In theory the afterburner on this EDF setup should be able to produce more thrust as the front end does not use up any oxygen. Taking it a bit further, RAM jets only have a turbine in them to get the air fast enough in order to start them. (eg SR71) An EDF with a small battery is a whole lot simpler and lighter. It might even be able to generate power once the ramjet kicks in.
I love this hobby, so much cool stuff to do and so little time... Sorry I will try this at home, its on my project list. :)
Specially liked this
First:
"A full write will be available soon detailing everything that went into this custom afterburner setup."
Then:
"This is our first "Don't Try This At Home" episodes, so please be safe and don't try this."
Keep up the great work.
From the mind of the mad sweed great things come.
Dear Josh, Josh and Chad,
can you make a review about the Hitech aurora 9, this would be very cool
Thank you very much
Fabian
What is the maximum speed reached ?
big thank
I guess it will look good but will it provide thrust too ?
Examples :
http://www.akamoto.co.uk/flaming-exhaust.asp#
http://www.ebay.co.uk/itm/Exhaust-flame-kit-Flame-Thrower-for-Classic-Cars-and-show-cars-/390774793222?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5afbfe2406
Thank you.
