The Flite Test Beginner Series is brought to you by Horizon Hobby.
Episode 8: Transmitters
Transmitters (TX for short)
What do they do?
Transmit the control information to your plane.
Things to consider when you are looking for a transmitter are Frequency, Number of Channels, Modes, Advanced Functions, and Cost.
Frequency / Protocol
72 MHZ -
- Older
- Longer Range
- Can interfere with others
2.4 GHZ
- Most common
- Shorter antenna
- Frequency hopping
- Proprietary protocols - Brand specific
Number of channels
4 or 5 Channel - Throttle/Rudder/Ailerons/Elevator
- Less expensive
- Not good to grow with
- Usually come with RTF
6 or more - Throttle/Rudder/Ailerons/Elevator/Landing Gear/Flaps
- 6 channels is usually all you need
- More expensive radios have nicer gimbals
Modes
- 1 and 2 are most common
- Everything Flite Test does involves MODE 2
- Different modes aren’t better… just different
Advanced Functions
- Display Screen
- Multiple Model Memories
- Training features (Buddy box)
- Expos - Gives you more precise control but still lets you use the full throw.
- Dual rates - Makes the servo move less or more in relation to the stick.
- Mixing - Example: Elevons http://flitetest.com/articles/Elevon_Mixing_
Cost - What makes the price go up?
- More channels
- Better quality
- The price of the RX’s
- Advanced features
- Better resolution
Expo
Video explaining both expos and dual rates: http://www.flitetest.com/articles/expos-dual-rates
Makes the stick softer around mid-stick (or quicker depending on the direction!)
Comes from the exponential curve in mathematics
Negative values on futaba and hitec, positive on Spectrum
Dual Rates
- Video explaining both expos and dual rates: http://www.flitetest.com/articles/expos-dual-rates
Makes the servo move less in relation to the stick
Usually set up on a switch so you can switch in mid flight
Great for maidening new planes
Some people prefer dual rates over expos (We say use both)
HorizonHobby-BeginnerSeries
The Turnigy 9X is a better radio for the money though - -more channels, more functions for a similar price, and you can modify it to be far more powerful.
The plane survived several ouchy crashes, with only one hot glue operation required when I really pounded into the ground at high speed (split some bamboo, crushed the nose, pushed the motor pod back an inch). Glue, tape, back in business.
So thanks to all the flitetest crew for helping me get started. I'm looking forward to learning and flying a lot more!
Tim
Great job on the "Beginner Series". I don't think of myself as a "beginner" but I always find something useful in every episode. WJ.
Any help would be greatly appreciated.
Note that Flysky gear is also sold under a couple of brand names, so you do actually get a little more choice. You can also use Eurgle v2 receivers and HobbyKing v2 receivers - all of them share the same radio protocol.
Svara - när kommer JA 37:an???
Guys: Good show! Thanks a lot!
http://i.imgur.com/AXr4QLP.jpg
So I would like to know what are the exact setting for programming the radio, which is a Fly Sky, FS-THX9X transmitter, and the APM.
Also the "servo" that is used on output "pin 7" of the APM does not respond to any stick controls? I appreciate any help...
