Elevon Mixing
by FliteTest | April 25, 2012 | (24) Posted in Tips
In this episode of Flite Test Josh and Josh talk about mixing! Watch as the team walks us through the process of mixing with 3 different Spektrum transmitters! Watch this video to see how to do it yourself.
RCDZK2011 on May 9, 2012
Hi FlightDeck. Your DX8 has the programming built in. You will plug you servos into the AIL and ELEV channels and set up the mixing in your DX8's Programming under 'wing/tail mix', If my memory serves me right you will than choose the ELVON or Vtail mixing.
And bobs you uncle Simple as that.
D
Flightdeck on May 8, 2012
Hello Fellas,
I purchased from hobbyking 6channel orange rx receivers which I plan to use with my DX8 transmitter. Should I use a y harness for the servos for elevon mixing? Also, do I connect the leads to the aileron connection? I never flown wing planes yet so still new at the elevon thing? I appreciate some feedback thanks. (Flightdeck)
D
RevJim1952 on July 28, 2014
The Vicar, Reverse the servo leads, elv to ail, ail to elv. Hope that helps
the vicar on June 13, 2014
Help! Ju st fired up my Dx6i with versa wing. Connected as per manual and turning the right stick right elevaters go up, to the left down. If I push forward it is like ailerons turning pull back is turning the other way. So close but not right. How do I change this any suggestions. Thanks in anticipation.
hcps-danielscb on October 23, 2014
does the dx4e do elevon mixing?
hafen8er on November 11, 2014
Anyone have luck mixing with a dx5e? No matter what I do controls are wrong. Left/right do up/down. Swapped wires reversed switches. If what I read it's not as easy as flipping a switch. Any help would be appreciated.
marc71 on July 11, 2015
Did you ever get it to work? Im having the same trouble
sorry i meant elevon feature thingy mo-bob whatever youcall it
I figured it out. I needed to turn the servo arms the same direction instead of pointing away from each other.
TuDawgs on September 6, 2015
What about the Turnigy i6 set up?
Using a dx4e.. built a versa wing and i have bound it. When i pull up or down on the stick it turns. When i puh left or right it goes up or down. I have the mix switch set to on. When i turn it off i only have alerons.
erad on May 1, 2018
Crazy! With your Video I got it working the way it should. Thanks.
Elevon Mixing
