The Bat Bone tricopter center plate is the newest installment to our Rotor Bones multirotor components.
We're still moving in at our new place and our set isn't ready yet, but today is a special day!
Introducing the Bat Bone tricopter body designed specifically for our Rotor Bones multirotor components.
The Bat Bone is made of 1.5mm, high density, black G-10 glass fiber board. The tricopter camera mount is also available in our store!
Similar to the Original Tricopter body, the Bat Bone can be setup with folding arms for compact storage.
The Bat Bone is customizable too! Check out David's custom v-tail quad design.
This tricopter body is designed to give you plenty of space to mount your gear within the frame, while making it easily accessible.
The interlocking cross-bracing makes for a very rigid and durable frame.
Using a Straight 13-370 Rotor Bones motor mount, Josh created a brace for his FatShark transmitter.
Designed to give you all kinds of mounting options, the Bat Bone is a great platform for your multirotor body.
If you're looking for a little more customization, the AnyCopter body may also be an option for you!
David built this hexicopter with the AnyCopter hub and customized it with the RCTIMER 2-Axis Brushless Gimbal For GoPro. You'll be seeing more about this hex and gimbal setup in future episodes!
The Rotor Bones multirotor components are designed to give you a durable cost effective option for creating your own multirotors.
The Bat Bone tricopter body is available HERE
We'd love to see the aircraft that you're working on! Be sure to post photos and video and join the discussion in the forum post for this article. More photos too! CLICK HERE!
When are we gonna see a FT version of the RCTimer camera gimbal? Are you thinking of it or should I just order one from RCTimer?
Cheers guys and keep up the good work
http://www.instructables.com/id/Brushless-Gimbal-for-Aerial-Photography-Drones/
Hope this helps ;)
You show a couple of multirotors on the show.
Could you say anything about flight time on the different setups?
Might be only me but I would like to see some quicktipps on multirotor setup vs flight time / lift capacity / flight movement.
I'm looking for a stable gopro setup (much like the hex) with flight time as main goal but others might like responsive movement instead.
I'm interested how you do it because all I can see is bright sky and dark ground.
Are there any hacks/modifications so the output would be the same as recorded video?
Thanks for help.
Can you tell us what were you guys using? And also whats the difference between the APM 2.5 and HK KK 2.0 board?
Thanks!
P.S. FT COULD YOU PLEASE LIST THE MOTORS AND ESCS USED IN THE VIDEO FOR THE BAT BONE
Now, adjusting all the software settings for the controlled board... That's another beast...
- are the motors standard brushless motors, or a special wind/setup
- weight that the brushless gimbal and controller will add
- what sort of multirotor will carry it?
I have the 3DR/Ardupilot quadcopter and would love to add it, but am not sure it would lift it, so overall weight.... or do I need a hex?
Mount equipment that doesn't mind a bit of vibration on the arms - ESCs and any power modules or OSD equipment can sit on the arms fine. Avoid putting video transmitters on the arms as the shaking from the motors will cause noise in the picture, or even breaking up.
I like very much to order from You. But the shipping costs...
For the Batbone Tricopter kit the Shipping costs to Belgium are 20.95 $, if a ad 2 extra booms, worth 4.50 $ then the costs are 40.95 $. That's a little extreme.
(1/2 Inch dowel is hard to find in Belgium, the best is 12 mm, but that is always a little bit smaller)
efbe
I assume that you are getting a much higher price when ordering the booms is because the size of the box changes. It sucks, but the blame does not lie at the FT teams feet, but rather at the feet of the shipping companies.
Hurry up and get the batbone kits back in stock! Take my money!! lol...
I really liked how Josh used a Rotor Bone leg to hold his video transmitter. I am going to use that trick!
I love the V-tail quad and think that it would be great to see morre details.
A Kit would of course be the top.
I had a question regarding the length of the booms on the batbone rig. What lengths do you guys recommend to have a similar layout as the original tricopter by David?
Thanks!
In Batbone uses 12x12mm booms and 25 cm of length. Same in Anycopter kit.
In Batbone V-tail by David uses 12x12 mm booms 21 cm on front 2 booms and 25 cm back booms.
Thanks
I started assembling Batbone. He found a very unpleasant thing. If you drill the holes and drilled them even a little at an angle of 90 degrees, then your engines will be stationed is not strictly in the horizontal plane! I just got burned on it. And now I have to take a new wooden booms, buy a special attachment for the drill to avoid this.
I highly recommend to drill holes perfectly centered and strictly at an angle of 90 degrees relative to the plane.
P.S. Sorry for my bad English.
thanks
