Callum. W
RC planes have movable
control surfaces that allow the pilot to change the flight path. The typical
movable surfaces are elevator, rudder and ailerons. To make the surfaces
movable the hobbyist must install hinges. There are different types of hinges
for different applications.
Pin hinges look much
like door hinges. There are two sections that interlock, and a pin locks the
sections together while allowing them to move. Pin hinges are very strong and
can be installed with pegs to add strength. To peg a hinge, drill a hole
through the hinge arm and glue a toothpick in the hole after the hinge has been
installed. The toothpick is later trimmed and sanded to be flush with the
control surface. The peg prevents the hinge from pulling out of the surface to
which it is attached. Pin hinges are used in larger gas-powered planes and are
typically installed with epoxy glue.
Iron-on Hinges
Iron-on hinges are
made from the covering material that is ironed on the plane. The hinges are
made of two strips of material bound together so that one side of the
heat-activated glue on the material faces up and the other side faces down. The
hinges must be installed in pairs, one side to the movable surface, the other to
a fixed surface. These hinges are used most commonly on elevators and rudders.
Attach one hinge end to the top side of the fixed surface, the other hinge
attaches to the underside of the movable surface. The second hinge must be
installed the opposite way. These hinges are very light, and you can keep the
gap between the fixed and movable surfaces very close. The hinges are good for
smaller, electric-powered planes.
Tape Hinges
Tape hinges are
usually made from a strip of clear packing tape. The tape is applied to both
the fixed and movable surfaces at the same time. Apply tape to the top surface
when it is deflected fully down. Another strip of tape is applied to the
underside of the surface when it is fully deflected up. These hinges are
limited to electric planes made of foam. Make sure to check these hinges
frequently as the tape tends to lose adhesion over time.
Thank
Carl
