FPV 5.8gHz with DIY CP Antennas
by schraut5 | May 9, 2012 | (9) Posted in Projects
Hey guys! Here is a simple FPV video showing you one of my favorite FPV planes and my homemade circularly polarized antennas that I fly with. These antennas are very easy to make and produce great results.
Video Tx/Rx: FoxTechFPV 5.8 ghz 200 mw
FPV Camera: Pixim Seawolf 690tvl WDR
Receiver Antenna: Homemade Skew Planar Wheel
Transmitter Antenna: Homemade Cloverleaf
FPV Battery: 1300 mAh 11.1V 3S 25C GensAce
OSD: CE OSD v1.5
G.Collins on May 9, 2012
nice flight bud, I mack these little clovers to, thay work great.
;-) G
Roberto on May 9, 2012
Great. Can you share how you build the antennas?
Thanks
schraut5 on May 9, 2012
If you check out my YouTube channel I made a build video for them!
Thanks. I saw it.
I am using a 900mhz transmitter. What you recommend me? What you think about this?
schraut5 on May 10, 2012
With 900 mhz use an inverted V antenna on your video transmitter and a patch antenna on the receiver.
subsonichobby on September 23, 2012
Here is good write up for DIY 900mHz inverted vee.
http://subsonichobby.blogspot.com/2012/09/diy-inverted-vee-antenna-for-fpv-900mhz.html
Bjarkix2 on May 9, 2012
how many mw are you using for you your FPV Transmitter?
5.8 ghz, 200 mW from FoxTechFPV
AlexanderNielsen9800 on May 16, 2012
what is your max range? and what was it with the standard antenna?
schraut5 on June 2, 2012
The standard antennas get really bad at about 1000 feet. With these I easily fly to 3000 feet (and only turn around because I don't want to lose RC signal - waiting for my dragon link...)
