We had a chance to talk with the guys from Model Plane Foam about their specially design polystyrene foam, which is made specifically for... model planes!
Unlike foamboard which has paper glued on it, and fanfold foam which typically comes in pink or blue and has perforations in it, MPF (Model Plane Foam) is 2 lb/cuft density, smooth, flat, unperforated, unskinned and white!
MPF can be cold - shaped on the edge of a table or heated with a heat gun to create great custom designs and shapes.
You can check out some samples of the planes that customers have made with MPF at the website: ModelPlaneFoam.com
Though, not currently available on their website, at the JR Indoor Electric Festival MPF was offering complete scratch built kit accessories containing motor, ESC, propeller, battery, and other accessories needed to build a full functioning foam plane!
We purchased a few boxes of MPF, so stay tuned for more details from Flite Test as we test it out!
To find out more check out ModelPlaneFoam.com
Check out the other interviews we had at this event:
