So I have been flying my Bixler with a GoPro attached and like many, I want to get the nose out of the video. So the majority of what I have seen has been hacking the nose off of the plane. Well I still want to fly my Bixler around like a normal plane so I have a few options. Get another Bixler and hack it’s nose off or be content with the nose being in my shots OR do something completely different.
I chose something completely different and started coming up with my interchangeable 2 headed Bixler or DR Jekyll and Mr. Hyde Bixler. This is still an experiment, since at this time I have not had it up in the air to see how it flies; the weather has not been very good for a test flight.
I decided I should cut the entire cockpit area off the plane then build a bulkhead that would be used to attach the cockpit back to it for normal flights and another for video flights, that way I could get the best of both worlds and still only use 1 Bixler.
Both heads have their own receiver, which allows me to setup different settings for essentially 2 planes and I used MPX connectors to make all the body mounted connections easier. I also decided to add a battery tray which I am hoping will make positioning the battery easier but also give the heads a good anchor so they don’t fall off. I did go a little overboard with making sure the heads stay secured and realized after gluing in the 4 magnets that they are a little too strong, which makes it a bit tough to pull the heads out, but at least I know I won’t be watching my plane decapitate itself mid-flight.
All-in-all it has been a learning experience and the next system will be different, but I have achieved my goal of having a plane I can fly normally with its nose attached as well as be able to fly it with nose free video.I would love to see what you all think and maybe together we can improve upon my initial design.
Here are some of the images I took during the build:
Later this winter I will be researching mods for that and possibly setting up my own. I did however stumble upon something at HK that I have not seen anyone talk about yet. Bixler 1 has been upgraded, which seems odd that they release Bixler V2 and then Bixler V1.1. The fixes they added to Bixler v1.1 basically improves several problems in both V1 and 2. They moved the elevator and rudder servos to the back of the plane with a new access hatch, they added V2 style screw in anchors for the wings, they mounted those screws from the top, rather than the bottom, etc. So basically, they improved everything except it looks like they didn't add flaps, like what the V2 has. I have ordered the new V1.1, which will be here in a few weeks and when it arrives I am going to see if I can sub the Bixler v1.1 body for the v2 body. If I can, I will have a Bixler2 with, better, rear placed servos, flaps and plenty of payload space.
Thanks for posting.
Do you use hot glue?
I've read that hot glue it's not good for epo, I'm waiting my bixler in a few days and don't know what glue to use in it.
Regards
Also I use a Stanley DualMelt Pro Glue Gun (model GR100). It has a low temp setting and some precision tips which helps minimize foam damage and allows you to inject it into small cracks. It's about the best glue gun I have found for foam and other projects.
I think you should make camera head a bit more aerodynamic to keep the flying characteristics like a normal plane
So far, I have made the right shape out of a piece of the molded package foam that my TV was packed in, but that stuff is so soft it will not hold up well.
Now, I am considering a few options. One would be glued layers of fan-fold that I shape or make a mold and fill it with a foam like Great Stuff.
Very well thought out.
Coolest thing I've seen in a while.
Very nice idea, thing you are on to something here...
