Have you watched the H-Quad Review? Well, in this episode we break down the H-Quad, from start to finish. This frame is not only a very stable platform, but it also is extremely versatile.
Building your own multicopter is a great way to learn more about multi-rotors, RC planes, and their components!
PLANS:
http://forum.flitetest.com/showthread.php?2357-H-Quad-Scratch-Build&p=29324#post29324
Watch the H-Quad Review:
http://flitetest.com/articles/H_Quad
Watch our Quad Programming video
Watch our Quad Setup video
Build your own Cloverleaf
http://rcexplorer.se/page14/CPantennas/CL/CL.html
HQuad PARTS:
DT750
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=6247&aff=247441
PROP SHAFT NUTS
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=6362&aff=247441
PLUSH 30AMP ESC
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=2164&aff=247441
2200 3 CELL BATTERY
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=8934&aff=247441
QUAD COPTER CONTROLL BOARD
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=19534&aff=247441
OR
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=12974&aff=247441
USB ASP PROGRAMMER
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=21321&aff=247441
PROPS (4 TYPES NEEDED)
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=22453&aff=247441
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=22452&aff=247441
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=22451&aff=247441
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=22450&aff=247441
XT-60
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=9572&aff=247441
BATTERY STRAP
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=11736&aff=247441
SILICON WIRE (2METERS)
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=9678&aff=247441
BULLET CONNECTORS (2 BAGS)
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=68&aff=247441
HEAT SHRINK TUBING
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=5279&aff=247441
STICKS: 1/2" OR 13MM POPLAR
1/8" OR 3MM LIGHT PLY
I have just finished my quad and I am now trying to program it. When I turn my yaw pot to 0 and wait for the double beep I turn the stick to 0 like your supposed to. Then I can control the motors, but only throttle....no directional control or gyro effect on the motors when you tip it. Then after returning the Y pot to 50 I have no control over anything and the gyros still will not change the motor speed. I need so much help! Such a noob!
if i throttle up the motors whilst in calibration they all start together.
However when i arm the board and throttle up the front left motor will start when i am at 70% throttle whereas the others start at 15%
BUT if i switch the data plug with any of the other motors then they will run slow but the original will not leading me to think its something to do with the board.
Yaw is 50% Pich is 0% roll is 50%
Software is the xcopter v4.7 kk by kapteinkuk
Also the yaw gyro control was reversed so Ive had to change that round, this fella explains how to do that http://www.youtube.com/watch?v=B6m49Cw3OFU
but apart from that it works real well, just got to get it all dialed in then I will post a vid
Just trying to get an idea of flight times...
multi-rotors like helicopters in general do not cover much ground (low ventilation), this model is encased ESC (low ventilation), on a warm day or hover or in the garage, you can really heat up your ESC; so go on and use the suggested one (30amp) which should cover you until winter arrives or you become an expert and fly fast all the time...
http://www.hobbyking.com/hobbyking/store/__21759__20CM_Male_to_Male_Servo_Lead_JR_26AWG_10pcs_set_.html
Also, not saying that I don't like some of the FPV but incorporate it into different stuff. FPV on twin twirl. FPV on a helicopter (not multirotor, an old school single rotor helicopter).
But I do miss something crazy like the flying cow, breaking glass challenge, or the tasers.
http://mxclouti.dphoto.com/#/album/1ed88m/photo/13057161
http://mxclouti.dphoto.com/#/album/1ed88m/photo/13069764
http://mxclouti.dphoto.com/#/album/1ed88m/photo/13069771
http://mxclouti.dphoto.com/#/album/1ed88m/photo/13069783
http://mxclouti.dphoto.com/#/album/1ed88m/photo/13069791
Reason for these questions.....I see nothing addressing transmitter. My xmtr. is a JR 8103 with a DSM-2 module.
Flash
Can I make the shaft shorter by cutting it and use a 4mm prop adapter ?
Throttle up, tx on, button 1 and 4 on kk2, powering kk2, beep signal, throttle down, release buttons
Whats a good replacement for the DT750 as they are always out of stock??
And what ESC to go with the suggestion.
Thanks
The DT750 can draw up to 18amps according HK.
So for this quad it's 18x4=72 amps.
The suggested LIPO is a 2200mAh 3S 25C which can deliver a max of 2200*25=55 amps.
Doesn't cause this potential issues?
That would be a very good alternative!
Can someone help?
Thanks!
