H-Quad by FliteTest
Rating: 4.92      61 ratings
Posted: July 9, 2012  |  48,258 views
INFLUENCE 93%
Imagine a quad-copter combined with a big shelf. Meet the H-Quad (HQuad). We didn't invent it, but Josh Bixler sure built a good one. It's not quite as aerobatic as an 'X' or '+' quad, however... it sure can haul a lot of FPV crap! Functional multirotors are gaining popularity, so we were certain this would be a worth while build.
Enjoy this entertaining review of our scratch built H-Quad.
Instructions on building you own H-Quad HERE:
http://flitetest.com/articles/H_Quad_Scratch_Build
Build your own Cloverleaf
http://rcexplorer.se/page14/CPantennas/CL/CL.html
PARTS:
DT750
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=6247&aff=247441
PROP SHAFT NUTS
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=6362&aff=247441
PLUSH 30AMP ESC
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=2164&aff=247441
2200 3 CELL BATTERY
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=8934&aff=247441
QUAD COPTER CONTROLL BOARD
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=19534&aff=247441
OR
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=12974&aff=247441
USB ASP PROGRAMMER
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=21321&aff=247441
PROPS    (4 TYPES NEEDED)
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=22453&aff=247441
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=22452&aff=247441
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=22451&aff=247441
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=22450&aff=247441
XT-60
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=9572&aff=247441
BATTERY STRAP
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=11736&aff=247441
SILICON WIRE (2METERS)
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=9678&aff=247441
BULLET CONNECTORS (2 BAGS)
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=68&aff=247441
HEAT SHRINK TUBING
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=5279&aff=247441
» Join the discussions on our forums
Comments
Eric Deagle July 9, 2012
looks like it has plenty of power! I'm to scared to fly my gopro without it in the protective case, this set up looks like it should be able to carry the gopro with its hard plastic case with no problem.
Will you post some more video from this once the props are ballanced? I'd like to see how stable the footage is with this platform.
Quai July 10, 2012
Would it be possible to find out how much this setup could lift without affecting the performance too much?
cwozny July 9, 2012
Awesome review, I always love seeing Josh Bixler doing something he's mildly new at. I was expecting the quadcopter to fall out of the sky when you said you hadn't had a glitch yet :P Can't wait to see the build video!
buddy July 9, 2012
Cool plane I just plane and quads handle totally different
KwangHo LEE July 11, 2012
Did you use which firmware ? can you give more specific information? I mean like the firmware name and version number.
ockay16 July 10, 2012
Really nice video, thanks!!
Can we have a building video?
Eric Deagle July 11, 2012
Thanks for the build video Josh! I am thinking of getting the materials this weekend and finally build me one.
Jake Wells July 10, 2012
Hey guys can you see if you can design it to fold up? I'm flying the F450 now but it doesn't fold up to take on a hike. God Bless
Scoodles93 October 3, 2012
love the body style.. i am currently building one myself.. i want to put my nikon 5100d on the bottom but i need to know which motor/esc to use? i was thinking prodrive 35-36 910kv with 60Amp esc..?? 13x6.5 prop..
you should do a BIG VERSION!! i love the cargo space :)
Dworf July 11, 2012
hey guys any info on how it flies with Hobbyking i86 Multi-Rotor Control Board? In build video you said you will test it with this board any info would be appreciated :)
buster232 July 12, 2012
Does anyone know what the approximate total cost of this is? airframe only no fpv gear
lluf July 10, 2012
Nice quad. What could be done to reduce the jelly-effect? David's videos are much smoother. C'mon Josh'n'Josh, you can do it ;)
biggles July 10, 2012
Ordered my stuff today and will begin building this weekend
dammuozz July 9, 2012
looks like a very nice quad!! never seen the H configuration before...I wonder what's the flight time with these batteries??
What's your quad flight weight withe the batery and gopro?
mgehrig July 9, 2012
Bring on the build video!!
biggles July 22, 2012
Ive just completed my h quad and just thought I would let people know about a couple of things to watch out for. I bought the hobby king v2.1 control board and the pots seem to work the other way round compared to joshes video about set up and from what I can gather from other sources it seems to be pot luck as to which way round yours will work. Also the yaw gyro control was reversed so Ive had to change that round, this fella explains how to do that http://www.youtube.com/watch?v=B6m49Cw3OFU but apart from that it works real well, just got to get it all dialed in then I will post a vid
Dworf July 10, 2012
can we get the plans for the frame? :)
cwozny July 11, 2012
Out of curiousity, why are you guys using the v2.1 KK board now instead of the v3? Is there an issue with the v3?
FliteTest July 11, 2012
It's just what we had on-hand.
Eric Deagle July 10, 2012
hobbyking is out of stock on the ESC's, what other esc's would you all recommend?
Norway_Ulrik July 11, 2012
Wait For HK to get the Turningy Plush 30A in Stock
yiduo.zhan January 27, 2013
Hi, I really like the design. You mentioned in the video that you planned to change two-blade propeller to three-blade propeller. What size of three-blade propeller will fit on this frame? What is the pros and cons of three-blade propeller compare to two-blade one?
lucserre February 2, 2013
How did you remove the long shaft sticking up from the stock DT750 motor?
rcrich April 21, 2013
what is a good replacement for the dt750? I cant wait out the backorder!!!! HELP
ox141jf December 7, 2012
I need some help, the board is setup and the esc's are calibrated
if i throttle up the motors whilst in calibration they all start together.
However when i arm the board and throttle up the rear rite motor will start when i am at 70% throttle whereas the others start at 15%
BUT if i switch the data plug with any of the other motors then they will run slow but the original will not leading me to think its something to do with the board.
Yaw is 50% Pich is 0% roll is 50%
Software is the xcopter v4.7 kk by kapteinkuk
feetball May 16, 2013
Did you calibrate the ESCs?
msavsani August 11, 2013
Hi... i am planning on making this Quad and the Plush 30A ESC are currently out of stock... so i am planning on buying the HK 20A ESC.. Are they good for this DT750 motor? i asked the people in HK, but some say its great.... and some say its not.. So i dont Know what to do..!!
chlguy April 13, 2014
This Comment Has Been Removed
Going to build one of these but figured I may go 4 inches wide for a little mor deck space. Also, thought about putting a dial servo to control a tiltable gopro platform for more fpv versatility. Also going to build a little foamboard full top canopy to make it a little more visually attractive. I'l post pics when I'm done.
Log In to leave comments
