I’ve always wanted to fly a gas plane. The smell of the fule and the sound of the tiny engine idling fascinated me. When I was really young, one of our neighbours flew nitro, which I think really inspired me. Resently I got to thinking I would like to try it out but the high price was intimidating, so I went and talked to our grounds keeper (I live on a boarding academy campus) and asked him if he had any weed-eaters that he didn’t need any more. He thought for a moment and then said he had two of them I could choose from. As soon as I could I ran over to the shed where the weed-eaters were kept and fired them up. The one ran nice and the other, not so nice, so I went with the one that ran nice—I suppose that was the logical thing to do. It was a 21cc Echo gt-225.
I did a bit of research and found that a few other people had done this before, but there was very little documentation. So, using this very helpful “Rules of Thumb” page I found on RC Groups I came up with my dimensions: Rules of Thumb
Wingspan: 8ft (96in)
Wing thickness: 2in
Cord: 16in
Wing Area: 1440 sq in
Fuselage: 6ft (72in)
Leading Edge of wing from back of prop: 14.5in
Horizontal Stabilizer:
SA: 360sq. in
L:30in
W:12in
Elevator: 3 in wide (SA: 90sq. in)
Vertical Stabilizer:
SA: 144sq. in
H: 16 in
L: 10in
Rudder: 3 in wide (SA: 48sq. in)
My next problem was trying to figure out what prop size to order from Hobby King. I did some more research and found a few people using 15-18in props, so I decided that I’d go with 16X6 props. I added three of them to my cart, tossed in five 35g servos and hit confirm order.
While my order was shipping, I turned to my weed-eater and begun tearing it apart. Slowly but surly the plastics came off until all that was left was a tiny little engine:
Now on one side of the engine there was a clutch and on the other there was the pull-start mechanism. I unthreaded both of them and then went to the shop on our campus and rummaged through a box of metric nuts and bolts (the thread on the crank-shaft was metric). My challenge now, was to find a way to attach the prop to the shaft. Sounds simple, but I found it was far more difficult.
In the end, I decided to try welding three of nuts together in a row. I threaded half of the three nuts onto the motor shaft and then thread into the other half, a bolt through the prop and therefore held the prop to the motor.
Next I asked our maintenance manager if I could have a 2x8ft. sheet of pink insulation foam. He agreed and I set to work cutting the trailing edge with a hand-saw, and then I cut a 45deg. angle with the table-saw on the leading edge. I rounded it off with sandpaper and she looked great! I cut a notch with the table-saw on the CG mark and glued a oak spar into the wing. cut some ailerons into the wings, and popped on the servos and, there it was.
The fuselage was a 2x2 that I cut at 6 feet long and then drilled big holes all the way down the length of the body to reduce weight. I then used the four bolts that held the pull-starter to the motor to bolt the engine to the body. I bent an aluminium piece for the gear and drilled holes in that too, just to lighten it up.
I bolted the wing to the body and to two aluminium angle pieces I screwed to the side of the fuselage. The original fuel tank from the weed-eater I bolted just under the wing:
For the horizontal stab I used foam-board doubled over. and the Vertical stab was just one layer thick. I cut control surfaces into them and it was ready to fly!
I gave the prop a flick and she fired up!
And lift off!
Final aproch...
Touch down!
Back on the ground, safe and sound! I learned a ton from this project and I hope it inspires others to try some far-out things they have been thinking about doing but never got around to trying. If you have any questions about the spesifics of the build don't hesitate to leave a comment!
Happy flying!
but I'm sure you can find it elsewhere...
let me know if this answers you question!
The way it is usually done with nitro/gas is to use the throttle trim. Set full trim for the idle adjustment and minimum trim will cut the engine.
its a 38g servo from HK
I'll post as soon as I'm done editing it!
I love the challenge you took on and great follow through. Could be a winner in the ugly stick contest.
Chicken stick or motor to start is a must, I still have the scars and lucky to have fingers
So the next biggest thing was to make RC go BIG... so a weedeater was next in line a guess!
http://www.rcuniverse.com/forum/engine-conversions-92/
Also, there are many home built conversion engines and aircraft for them over on spadworld.net.
http://spadworld.net/forum/viewforum.php?f=11&sid=558fdae27b6d880333743b21b0e090c3
This is not to take anything away from FT, just to remind folks that there are other sites with years and years of experience that can be of help. One cannot expect to find everything in one place. :-)
Good luck on your next project!
