Ugly Stick
by pete stanford | April 12, 2014 | (10) Posted in Just Fun
I've now built, flown, crashed, repaired, flown, crashed and totalled a few of the Flite Test swappables.  Every one of them was great but last weekend was a disaster and I lost three of them in one day.   I'm going to an all electric meet this Sunday but got nothing to fly.  I could have downloaded another plan but I decided I needed a plane that could do everything.  The obvious choice of course was a Stick   I got onto Google Images and typed in 'RC Stick Plans'.   I printed out a set of the original Kraft plans onto A4 size paper.  From this I took measurements and multiplied everything by 3.  This gave me a wingspan of just under 1000mm.   Now here in Australia, a mate of mine and I have found foam board at Office Works.  I wish it was $1 per sheet but it isn't.  These sheets are 750mm x 500mm and come in several colours.  I made a two piece wing with similar construction techniques to the Spitfire but with square ends and constant cord, and I joined the spars with a slight dihedral (don't ask how much, thats the fun of scratch building).  The fuse is not built as a swappable but could easily be.
The motor/ESC combo is a Turnigy 2836 1100Kv with a Plush 40Amp ESC and a 9x6 prop.  Battery is a 2700 4S.  I didn't make a rudder but now I wish I had as she is very aerobatic.
Undercarriage setup is similar to the Old Speedster with a rubber band bungee setup and BBQ skewer tail skid.
She takes off in about three feet and can be flown very fast or fairly slow.  As I said earlier, it is very strong and fully aerobatic and if I had included a large rudder would also be good for 3D.  Anyway, she flies great which is typical of the Stick design which is why I built it in the first place.
sailorJohn on May 6, 2014
Try youtube--- Experimental airlines--- "Noob Tube" Fast build, increase control surfaces and a wild and crazy flyer ,add flitetest landing gear and enjoy.
Bob_Curtains on May 9, 2014
Great job man, i loved this plane as a kid. All you need is the German cross on the tail and your done (obviously the Rudder also.... lol). Very nice sir!
Red20RC on May 8, 2014
Awesome! You can't go wrong with an Ugly Stick :-)
LordVader on May 6, 2014
Very nice, thanks for sharing. You could always add the rudder, use a simple tape hinge or the hot glue hinge.
Flying Fox on September 11, 2014
Awesome plane.
charleyza on November 27, 2014
Very nice, thank you for sharing :) I have never scratch built but I'm going to try starting with one of these sticks.
Found some PDF's online : http://www.rcgroups.com/forums/showthread.php?t=490620
I see yours has a curved wing but the plans I found has a flat wing - does this make a difference?
Also I am unsure what materials to use as the recommended 6mm Depron would surely bend on a flat wing?
Perhaps Balsa Wood or Foam core would work better?
Ugly Stick
