To the FliteTest Community,
Ty and Henry finished up our first ever glider that was to be pulled by our Apprentice, very much like what others have done on other channels, especially FliteTest. Now we are not experts and any advice that you give us we will take into Season 5 next year. The 8th grade boys fixed the glider and left it for the next crew to work on. It was still a success though, the kids had a lot of fun and we learned a lot from the experience. We will definitely be working on big projects like this in the future.
For more information about the program please visit us at: http://www.mesarcfoamfighters.com/
As always, thank you for the support!
MESArcFF Team
Colton our top pilot took lead on the towing of the glider with the Apprentice 15e
Ty seen here walking the glider before it took off.
Fun getting it all setup!
You have to mount a Gopro for something like this.
Ty seen here working the release mechanism, making sure that everything is just right.
Holy moly it worked, Henry says just keep flying lets see what happens.
On the first attempt the release opened and the glider landed just behind the infield grass.
The second chance went great until the plane started to roll and then it got caught up bringing both planes down fast. It was actually pretty cool!
You can see how close we were to the houses, bring it down Colton, bring it down NOW! Lol.
Recap, it was still a success, too much fun! Way to go guys. Thanks to FliteTest for a glider plan that the kids were able to build and have fun with.
A lot of what I suggest below is true for full sized gliders as well.
In my experience towing too fast makes the glider unstable (in actual fact the controls become very sensitive because of the increased air speed) so only just enough speed to get both aircraft into the air safety - OR - Dual rates on the glider to give reduced control movement on take off.
A long tow line makes towing easier.
Keeping level or just below the tow aircraft makes things easier - Going above the tow aircraft pulls the tail up. With a model this is really really hard to judge.
As soon as things go wrong, excessive movement on the part of the glider for example - The tow aircraft should be able to jettison the tow line. Better lose the glider (which may well land successfully from a low altitude) than the tow aircraft.
Have procedures in place to deal with the failures - AND - practice, tow line break, Instability, landing from low altitude (unless unsafe land direct ahead), tow aircraft engine failure.. All these things WILL happen.
I wound add ailerons in the wing tips rather then in the inner portion of the wings. It takes a lot of throw to roll it even just a bit with as much polyhedral as the FTSS has.
What do you guys think?
1. put the towline at the top of the tow plane at about the CG
-when the glider pulls up or doesn´t fly exactly behind the tower it wont disturb the tow plane
2. actually i think its way easier towing with just rudder and elevator
-more stable (high dihedral, actually why i like it more then with aileron)
-not much to control and care about when towing
3. don`t get faster then the sailplane wants to
-rudder and elevator only models are normally for low speeds so when they get to fast get rly touchie on the controls (thats why most do a barrel roll)
everything based on personal experience!!!!!
first towing was with my mate. We got an se youngster (http://www.cmc-versand.de/Simprop/0310107-SE-Youngster-arnr-16-0310107.html) as a kit from our club and he has a Fun Cub. absolutly no Problem! Perfectly stable and easy. I figured out when turning a 2 CH airplane has to slightly steer out of the turn so at a left turn the sailplane hast to be controlled slightly to the right. we also towed an graupner Amigo 4 also 2Ch airplane. We are also towing a ,a bit faster, 3ch hangglider and i think its quite a bit harder to stay on track! and u actually need rudder to also slightly control out of the turn so the towline doesn`t get slack!
