time elapsed build from plans of the ft cruzer
by brianm311 | April 21, 2013 | (5) Posted in Projects
  this is a short video of my ft cruzer build from the plans online, havent got any motors yet but the maiden will be soon an the video will be as well! i am useing the power pack from lazer toyz for the motors an speed controlers, servos an battery,it's a great deal for the price an saves alot of time matching everything up! sweet plane and can't wait to see it in the air with my own eyes once again thanx to josh,josh,chad,the sweede an every one else involved there at flite test!! keep up the good work so i can keep on adding new planes to my hanger!!
rallyman on April 22, 2013
Oh-oh - forgot to put the servos inside the fusilage - oh well. WHERE DID YOU GET PLANS OR DIMENSIONS FOR THE 2 POSTERBOARD BITS FOR THE BACK CANOPY AND THE NOSE PIECE?
brianm311 on April 23, 2013
I didn't have them on the prints so I just cut it out similar to the blender,for the nose I cut the piece linger attached it to the bottom and than just measured it out from there.
as for the servos I couldn't wait to build it so I decided I would put them in the body like the ft-3d
rcspaceflight on April 23, 2013
I eventually want to make a timelapse build video and I was wondering if you used a camera that takes photos at set intervals or if you recorded video and then sped it up.
steve s on April 22, 2013
I watched him build it, and he goes like a maniac..............steve.s
I did the time lapse with my camera,it's a Samsung hmx-f80 relly easy to use,
FLYitRC on April 23, 2013
You will not be disappointed by this plane. such a great Platform for just having fun flying! it has some get up and go too!!!
brianm311 on April 24, 2013
I am chomping at the bit waitng for parts! can't wait to fly it looks like it will be a good time an it will also be my first twin engine,just purchased a fat shark system and will be fpv in this one for sure!!
tweelix on September 14, 2013
How did you get the plans on the foam board and what dimensions was it?
brianm311 on September 16, 2013
first I printed everything in tile so that the inch scale on the print was exactly an inch, I than taped them together and cut them out, I than traced the outside of the plans on the foam board and transferred everything after that
tweelix on September 16, 2013
DAAAAYYUM this is gonna take longer than i thought
brianm311 on September 17, 2013
lol not to bad I just built one for a friend last week the whole build was about 31/2 to 4 hours if you lightly trace the lines on the print after you trace the outside it helps when transferring the rest of the lines on to the foam board, the longest part I found was cutting out the prints
