Hello from Russia! :)
My name is Dmitry. The first time I publish an article on this awesome resource that brought me back to the radio-controlled models after a long break!
With all my heart I thank Josh Bixler, Joshua Scott, David Wingistal, Chad and the whole team!
Well, now, I will just share a little video about the adventures batbone in Moscow. :)
This is my first video of the radio-controlled models. I hope you enjoy it.
In multirotor I'm newbie. And there is a small problem that I can not decide. Ruder trikopter little twists. Increase, the sensitivity setting does not help. What am I doing wrong? Can somebody share the settings? :)
Specs of my tricopter:
Frame - Batbone tricopter
Camera holder from flitetest.
Board - HK KK2.0 v. 1.6
ESC - HK BS 30A - Simonk
Motors - NTP 2826 1250kv
Servo - bms-385dmax
Props - APC 8x4,5 in
Battery - Turnigy nano 2700 mah
Onboard camera - Gopro 3 black
P.S. I apologize for my bad English.
1: Adjust the OFFSET on the Rudder in Mixer Editor -OR-
2: Just adjust your trim on the rudder of your radio.
The board displays all channel settings in the "0" position, but for this I had to use sub trim on the transmitter. Without the sub-trims board shows the position "4".
One thing confuses me a bit. I flew in helicopters a lot, and there absolutely can not be sub-trims channel tail! And we need to expose the central position of the blades 11 degrees. Perhaps here is the exact same problem? And I need to remove the tail and put SUB-TRIM mechanical center position 11 degrees inclination of the engine?
Я тоже из России. Извините, что не в тему, но подскажите, как связаться с Вами по почте или в личку (не нашел куда писать). Есть несколько вопросов.
Спасибо!
