If you have a Taranis Radio, one of the nifty features is being able to assign pictures to your planes. I've gone through and made some images you can drop straight into your transmitter.
To install them, just put your micro SD card into your PC, and copy these images into the BMP folder. Now to assign them to a model, make sure your SD card is now back in your transmitter. You need to press the menu button quickly, then select your model, Press the Page button and scroll down to Model Image. From there you should find the list of all the model images in your transmitter, and if you've done everything correctly all the flitetest planes should be there.
They are bmp files, so I've got them in a Zip File, or you can get them at the following links.
Enjoy :)
Dave
Great stuff!!! If you come across any additional BMP's or sound files, please post them as well.Thanks.
You could also post this to http://rcsettings.com/index.php/viewcategory/8-icons
Keep up!
http://taranis.myhangar.de/imagesconverter/
Neil
