Hello everyone! After building many of the FT designs I decided to take a shot at some of my own and I thought this one would be worth making an article about! I started flying pusher props after building the Alpha jet and the Vector which were so great to fly! The elevon controls made it so easy and comfortable so I decided to take a crack at my own pusher jet.
This is the first prototype. It flew ok but after a couple bad crashes it was time to upgrade. I traced out the old jet and enlarged the wings, the elevon control surfaces and widened the body a little bit
adding a bbq skewer for a inner spar a scoring out a piece of foam to add for extra support. Works great!
I created an airfoil using the same technique as most other wings in the flite test catalog and formed the body with a little inspiration of Matjey’s yak 130 mj ( which is awesome! Huge shout out! Thank you! Go check it out) the nose section and fuselage are basically off the alpha. Just longer towards motor mount with a custom belly pan. It has a 26”wingspan and overall length of twenty nine inches. I scaled it down using grid paper from full size so I will try to make plans for download in the near future.
canopy is a quick alteration of the alpha and is attached with Velcro on the front back and both sides which works very well!
It is powered off the F pack but I had to use a 20 amp predator esc because that’s all I had and a 3s 800mh battery. (also because that’s all I have) The prop is a 6x4 APC pusher. Seems to do the job. Like I mentioned earlier it’s an elevon system which I used 2 9 gram servos, but will probably change to ailerons and elevator in the future.
while waiting for the weather to cooperate I gave it a little flare. Didn’t go crazy with it cause I wasn’t sure if it would fly
Eventually I did get to maiden it and was very happy with the results. Check out the video! Sorry poor camera angle I was flying solo. I hope ya’ll enjoyed my first article and if you are interested in building one for yourself I will do my best to get plans up in the future. Thank you so much to Flite Test and this awesome community. I hope one day to bring a monster version of this to a Flite fest or to Edgewater on a random getaway! Happy flying!!!
