Super easy Bixler Hanger
by tmask32 | March 15, 2013 | (9) Posted in Projects
This is a super easy wall mount hanger for your Bixler. An alternative to other hanging methods.
Materials you will need: aprox 4' of 3/4"pvc
                                   6 -3/4" PVC elbows
                                   6" section of 3/4" id pipe insulation
                                   4 to 6 screws and anchors for mounting
  Cut and assemble  as per the pictures. You can use cement if you want but I just pressed everything together firmly. With the exception of the front "u" shaped piece, leave that one loose, Add the piece of foam to protect the plane. And secure it to a wall.
  To use simply remove the front "u" shaped piece set the plane in against the wall and replace the front piece. Adjust the top two elbows to help hold the plane center.
Mirabile Visu on March 16, 2013
Very useful, thank you.
Atarix777 on March 17, 2013
Great Idea, i was looking right now for something to hang my bixler on the wall! :D
foghe on March 18, 2013
perfetto
Norlas on May 24, 2013
Great idea! I will be making one this weekend. Love the low cost/simple to use idea. Thanks
