Spektrum Flaperon Setup - Full Tutorial
by FliteTest | March 6, 2019 | (10) Posted in How To
Here's how to program flapperons on your Spektrum transmitter, including speed and multi-angled options.
Adding flapperons to some appropriate models can be a great way to add a little more dynamic ability to an airplane's capabilities. If you don't have dedicated flaps, not a problem! You can simply deflect your ailerons down whilst retaining most of your roll authority. Here's how you set up flapperons on a Spektrum transmitter.
Gear
Today we’re going to be using a Spektrum DX9 and an FT Scout available on the Flite Test Store. You can use any model with large ailerons. We wouldn't recommend this for scale warbirds, jets and airplanes like that, but many of our FT designs work just fine. If you're unsure, ask someone on the Flite Test Forum.
Process
1. Go into System Setup Menu
2Click 'Aircraft Type'.
3. Set ‘Wing’ from ‘Normal’ to ‘ Flaperon'.
4. Go back to the function list. You should find a newly available page called 'Flap System’. Click on it.
5. Select the transmitter switch you want to operate your flaps with.
6. You can adjust throws of the flaps by changing the numbers referring to each position of the switch. You can also change the speed of the flap movement.
We hope this tutorial was helpful to you. If you would recommend it, hit that like button!
Article by James Whomsley
Editor of FliteTest.com
Contact: james@flitetest.com
YouTube Channel: www.youtube.com/projectairaviation
rblubaugh on March 7, 2019
Thanks for the replies.
Bob
winglet on March 7, 2019
The Scout doesn't have ailerons? Nine does. Looks like the one in the picture does too. Flaperon setup is about the same with the DX6 I'm using and I assume the 8. DXI6i could be different.
Thank you. Very useful little article. I just set my newest Scout up this way.
by the way, yes. It takes two servos. No Y connector.
Gryf on March 7, 2019
By the way, I’m not sure why James used the Scout for his illustration, as it doesn’t have ailerons... ;-)
rblubaugh on March 6, 2019
This is well and good for those who have a DX9, but about those who have a DX6, or DX 6i or DX8 or other DX transmitter? You seem to be leaving them out in the cold.
Bob
esandel9 on March 8, 2019
The process is still the same. I have done it multiple times
Just a guess, but it looks like this works through the Aileron channel, so you might be okay with it. I had the same question, since I use a DX6 myself. I want to try this when I have a chance.
Slowjo on December 13, 2019
works on my DX6e
bajamrbill on March 23, 2019
How does that work on a dx6i?
Now that I’ve had another look at the photos above, it appears that you need to have your ailerons on two servos, vs. one servo with a Y-connector. But again, I have yet to try this setup so I don’t know for sure.
denpete on June 20, 2020
I like that you kept this simple for us newbees, thanks. Denpete
luke k on April 13, 2020
so i want to program flaperons in my force rc f18 pnp jet but when i do it one of the ailerons goes up instead of down and i have a y-connector going into the rx but the rx only has one plug for ailerons. so can you leave me a comment please and help!
Dprintz on September 19, 2021
I have the same problem. Did you get a corrective reply from anyone?
