My mSR-X and mCP-X v2 copters had motor problems.
I added a lubricant, Harken OneDrop Ball Bearing Conditioner to the motor. it takes about some time to get the motor to come back. I use this on my boat. West Marine sells it.
You run the motor until warm. Put one SMALL drop on the motor on the shaft side and let the motor sit over night with the shaft pointing to the ceiling. I use a soldering helping hands aligator clip. Do this slowly! One SMALL drop per application and let it sit over night.
The sqweeling and cluncking will go away. On the copters the the tail wiggle goes away when you do this to the tail motor. Log In to reply
