The Skartec Cessna182 is a great intermidiate plane.It comes with every thing you nedd to get flying. It comes with a good 7channel transmitter. A 1100mah 11.1v 3s battery that allows good 15 minute flight times.It also comes with a simulator and cables with a USB that allows you to plug the transmitter into the computer simulator. The plane its self is good quality but the tail and rudder could be a bit stonger but they do the job fine. The brushless motor provides plenty of power and has sufficent power to perfom some good aerobatics.
The bottom line. I would definitly buy this plane again. It doesn't cost too much,comes with good electronics,comes with a good Tx and is alot of fun.The simulator is brilliant and realistic and allows you to perfect aerobatics and other general things.
