Ok so here is my scratch built chimera fpv wing
It is all made out of $tree foam and is built relatively similar to the ft versa wing. I got the basic dimensions of a pic from stone blue airline's facebook. Thanks to IBcrazy for the awesome plane and i hope u all like it
Fist here is the lower part of the wing
Now here it is with the top taped on to it
and here is is with all the electronics added and ready to fly
here is the electronics bay
Here are a few more picks of it
I am running 2 2200mah 3cells with a 50 amp speed control and a 1020 kv motor with a 9" prop.
It flies grate and is super stable.
Also mine has a 45" wing span.
I have a storm osd on the way that i'm gonna put in it and than all be able to see its full potential.
also im working on some plans for it
Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
Log Out Home
