Scratch build PC-7 Steerable Front gear
by Felix Lepi | September 19, 2017 | (3) Posted in Projects
SPECS:
LENGTH: 70cm
CG: 3,5cm from LE
WINGSPAN: 42cm
DRY WEIGHT: 320g
ALL UP WEIGHT : 560g
RECOMMENDED SETTINGS
THROW EXPO
AILERON    - 20°30%
ELEVATOR  - 20°30%
RUDDER        - 20°30%
RECOMMENDED BEGINNER POWER
Power Pack C or F
Battery:  1500-2200mAh
Design goals:
1. 3  weels for nice Landings
2. first weel steerable
3. use for Rudder and frontweel the same Servo
4. coppy a real plane
So I chose The Pilatus PC-7. It has 3 wheels and is simple to build because it has a narrow fuselage.
The Wing was the only thing that was difficult to make but you will see in the build log how I solve the problem.
Build
(not the real plans)
Spar a middle Wing
add the landing gear reinforcement and the other wing parts finally Glue it together
complete Wing
Fuselage
Tailsection
Servos
Front landing gear Steering
Gear
Powerpod install with Electronics
Finished Aircraft
The flight video will come soon. I test it one time but the CG was not correct. But the plane tracks great. But the funniest thing is the front gear - it makes the plane so much fun to drive, you don't want to start!
She dies
I haven't drawn the Plans yet but if you want plans I will make some.
If more Pilots want to build my PC-7  I will also make a Build video for you.
JW34 on November 6, 2017
Would also like to see plans for this plane.
Felix Lepi on November 15, 2017
Plans are in process
themistocles3 on November 28, 2017
Very clean looking build. I'd love to see some more detail on the construction of the front gear. Excellent looking plane!
Raccoonworks on November 6, 2017
Nice build article! I would love to see plans for the PC-7. It looks like such an interesting build! Not often I come across a scratch built fomie with landing gear let alone steerable.
