Scrap Parts P51C
by brianm311 | January 31, 2016 | (0) Posted in Projects
Here's are the parts I am starting with: a wing and tail section from my old Sensei and the remains of another build that I will use as the print for my body.
I cut the XP apart so I can use the body as a template for the new plane.
Upper turtle deck and tail section removed:
I traced the shape on to new foam board:
Figuring in the tail section from the Sensei:
Let the cutting begin!!
Cutting up some bulkheads for the inner body support:
Here you can see some of the bulkheads in place:
Tail section mounted:
Here you can see I incorporate the old control lines from the sensei into the P51C:
Servo tray installed:
Wing support going into place:
Controls in place:
You can see the old glue on the control lines from the original plane:
Servos all mounted in and ready to be tested:
All centered and ready to go!
I think I can make it look like this!!
Tail skid going in place. I used some wire from Home Depot for holding up insulation for this, and I used it for my landing gear as well!!
Lower bulkheads:
Lower bulkheads in place:
Upper bulkheads in place:
I covered the bulkheads with construction paper:
I used the motor mount from an e-flight apprentice for the thrust angle:
Here you can see the body fully covered and ready for paint:
Here you can see the landing gear I bent from the insulation holders I got at Home Depot:
Driver canopy cut and in place:
Battery hatch showing space inside for extra battery:
I used olive green camo paint from Wal-Mart. It took a lot of light coats to cover everything but the finish was nice and it didn't bother the foam at all!!
Getting the graphics applied for these. I printed the images on paper then cut them out and used clear tape to apply them.
Ready for its maiden!
LordVader on February 20, 2016
Very cool build, always good to see old planes and parts being reborn into a new plane to continue on.
brianm311 on February 22, 2016
thanx!
Scrap Parts P51C
