Of all the swappables, I find the Bloody Wonder gives me more fun per mAh than the others. I always felt like one thing was missing, and as I was ghosting the rudder one day I said that was it.
I started by cutting the fins off of my wonder and making new ones without the notch at the back.
I cut the hinge in line with the top corner and glued them on with an angle piece of foam top and bottom for reinforcement.
I have the hinge in line with the elevator's. Knowing I needed room for inside movement I cut the elevator to allow for it, it did not lessen the performance of the elevator to any degree that I could tell. I then added a servo between the aileron and elevator servo and ran control rods to the inside of both control surfaces.
That added quite a bit of weight to aft but a shift of the battery and she was back to balanced. Now I just have to maiden the new Wonder
I am giddy as a schoolgirl about my new Wonder, the rudders add a whole new level of Holy Craptitude to the experience. It adds nothing if you want this bird for combat, but for flying squirrelly like I like to it does the trick. I did find that my roll rate was diminished by the larger stabilizers and will increase the aileron throws for the next flight. I highly recommend metal gears for the rudder servos because they are so unprotected in any foul landing. I have the cheapest digital metal gears in existance on this thing and I bounced it a dozen times today and she is still going strong.
Basically make the rudder out of the top half of the Vertical Stabilizers and hinge it parallel to the trailing edge. Might have a slight elevator effect, but hey, it would still be interesting.
Only reason I haven't done it, is my CG is too far back without battery now, so adding another servo and wires etc would make it near impossible to balance without dead weight such as washers.
You could build one with an extended nose, that would move the motor and battery forward to make up for the additions you want to do in the back with very little added weight. Less than a half inch would cover the control rods and horns, if you look at the way I did mine, the new servo is right on the cg so it's negated.
Also, I've made a symmetrical wing on it. I'm planning on making an article later :)
Thanks for sharing the rudder wonder! With my helicopter background, it is impossible not to use the rudder stick... Now it has some use, too! Rather than just ghosting ;)
