Installing a small but easy bomb/parachute drop on the Rotor Bones Anycopter hub
Small cheap 9 gram servo from my box of parts that is hot glued to the front of the hub and hooked up an extra chanel on your reciever.
rubber band on opposite side of the servo that is zip tied to a hole on the frame for an anchor point(make sure the hole is in the center because there is two and one is slightly to one side)
to load pull rubberband under the frame and over the battery and place the band on top of the servo arm(simply flip the switch on your transmitter that will move the servo to position and the rubberband will slip off be careful to always put the servo back in the origional position bacause the arm will push againt the hub and could burn out your servo and ruin it)
top view with the hobby king KK2.0 board
home made cargo parachute to drop
folding the chute
one packed parachute
