In this article, James takes us through his newest twin-engine plane built for experimentation!
I’ve always love the idea of creating a plane that’s just about capable of anything: dropping parachutes, towing gliders, flying aerobatics with some serious differential thrust - all of it. Of course, some of our Flite Test designs (such as the Guinea Pig) can do all of this, but I wanted to see if I could design something a bit different. Here’s what I came up with.
The main mission for this plane is to carry out as many science experiments as possible, including testing the Space Shuttle featured in an article from last week.
The idea is to build different pods that fit to the underside. These can be designed and built separately for various missions. These could include:
- Bomb drops
- Glider releases
- Zero gravity pods (like NASA’s reduced-gravity aircraft)
Spec
- Wingspan: 50” (1270mm)
- Length: 43” (1100mm)
- Weight (with batteries): 1.1kg
- Batteries: 2x 3-4s 1000mAh
- Motors: 2x Team Blacksheep 1000kv
- Channels: 7
- Flaps: Included
Flight Video
Dealing It In
Often with a new plane, and especially with a brand new design, you’ll need to work out a few small issues to get it flying just so. This can be as simple as trimming for straight and level flight. This plane needed a little more than this though.
The first launch didn’t go to plan.
After working out that the plane needed some more power and a decent throw to get it heading skyward, rather than bound for the deck, we could get more of an idea of how the thing was flying. Usually, you notice whether there are any obvious problems within the first five seconds.
What was immediately apparent with this aircraft was that it seemed to be flying a very odd attitude. For anyone who doesn’t know, the attitude of an aircraft is the angle it is flying at relative the oncoming wind/airflow.
This plane needed a ton of up-trim, suggesting it was nose heavy despite the CG checks looking spot on. This resulted in the plane flying at a rather ‘flared’ angle - nose high, tail low, as if it were coming in for a landing constantly.
After some thought post flight, I think the problem may be with the angle of the wing. With a more positive angle of attack, the entire plane should be less inclined to fly at such a positive angle all the time, instead relying on the Newtonian effect of lift pressing on the underside of the wing. A few degrees should do.
In addition to this, the CG will be moved rearward some more. Adjusting the batteries whilst out at the field seemed to help, so I plan on experimenting with this some more to find the sweet spot.
More Projects
If you enjoyed reading about this project, you might also enjoy these! Check them out:
Make a Thrust Vectoring Jet! - Build Log
Building an R/C Space Shuttle Glider
Article by James Whomsley
Editor of FliteTest.com
Contact: james@flitetest.com
YouTube Channel: www.youtube.com/projectairaviation
