Raiden Flight Review
by nerdnic | October 5, 2015 | (24) Posted in Reviews
DETAILS
The Raiden is a community designed plane by Kevin Matusik. This is the first airplane outside of my own design that I’ve officially reviewed. If you'd like to see me review others please let me know!
SPECS
WINGSPAN 40in
FUSE 38
CHANNELS 3
WEIGHT AUW TBD
ELECTRONICS
MOTOR - 1400kv 250w
PROP - 8x4 APC
ESC - 25a
BATTERY - 2200 3s
SERVOS - 2x 9g
BUILD DIFFICULTY
Beginner – You’ve never flown a plane before, let alone done a scratch build
Novice – You’ve flown a plane but have no experience with scratch building
Intermediate – You’ve flown and built a few FT style planes before
Advanced – You’ve mastered the standard FT build style and are looking for a new challenge
Expert – You’ve mastered all build techniques and aren't afraid to improvise or tackle tedious builds
PILOT SKILL
Intermediate
MATERIALS
4 sheets of DTFB or RossFB
Push rods
Control horns
Hot glue
PICTURES
The Raiden is an exciting canard plane with very forgiving characteristics. Kevin sent me a kit a few months back and I was able to walk through building and reviewing it.
I was very surprised by how light it felt in the air and by its stability. There was no tendency to stall violently, in fact, it doesn’t even nose over. It just sinks. Recovery was very easy also.
I was able to get some great air to air shots while flying the Raiden!
Loops and rolls were good but a little mushy. This is expected based on how floaty it feels. Overall this makes it very easy and forgiving to fly.
What a great flyer!
Overall the Raiden built smoothly and flew exceptional. If you’ve been looking for a unique looking plane while not sacrificing good flight characteristics then the Raiden should be your next build. Great job, Kevin!
For full details, plans, kit information, and more flight videos of the Raiden check out Kevin's articles linked below.
blackkrystal73 on October 6, 2015
Nice review Nic. Thank you very much. looks like you put a lot of work into it.
Bayboos
I use a 2212 1400-1500kv motor with 8X4 prop. It will go vertical forever with that set up so you can fly it with less.
CG is 2 7/16 forward of the main wing, I have flown it nose heavy but never tail heavy. it will tolerate a lot of nose weight.
I fly with all the throws, even the FPV version. Raiden can be very acrobatic with a really high roll rate. She'll even fly inverted well, which blows my mind with the canards pitched the way they are.
Hope this helps.
Thanks again Nic I appreciate it.
Kevin
Bayboos on October 6, 2015
Nice work, Nic! It's very nice of you that you decided to try on, review and share this beautiful, unique "community design".
One thing I'm missing over here is a handful of technical details (does the wing have spar reinforced in any way, is the canard moving or fixed, is the CoG range wide or narrow etc.), and it's hard for me to believe some specs (is AUW really just 80g? That's less than most profile indoor flyers! Also: motor info is way incomplete, Kv number is not enough). It would also be nice to have a link where we could find more about the plane and it's author. But other than that, this is the type of article I'd definitely see more of; thanks.
There are tons of other designs worth sharing; keep up the good work!
nerdnic on October 6, 2015
Bayboos,
I have corrected some of the specs, good catch! For the other details I should have gone into more depth. I'll take this as feedback for the next review I do. To answer your questions now, though:
1. The spar is just foam. It uses bracing similar to the Versa.
2. Canards are fixed at a slight positive angle of attack. You could easily add a servo and make them variable.
3. CG needs to be pretty dead on but I didn't do a lot of testing forward/aft.
4. Kevin's original articles with more details and the plans are linked at the bottom of this article.
Thank you for the feedback and let me know if you have anymore questions!
Thanks for your answers. Good luck, and Have Fun!
Flynn on October 12, 2015
Great design and 5 stars for thinking outside the box! Awesome job Kevin Matusik!!
knoticalknots on April 24, 2016
I WOULD LIKE TO BUILD THE TWIN TAIL RAIDEN FROM EATHER A KIT OR PLANS CAN YOU TELL WERE I CAN GET EATHER
DAN
blackkrystal73 on February 10, 2017
Here are the latest plans... Enjoy...
https://www.dropbox.com/s/c0wis2lyeugbbgw/Raiden%20Version%205.zip?dl=0
