Quick Tip KK 2.0 Voltage Alarm Setup & Mounting
by StoneBlueAirlines | May 2, 2013 | (0) Posted in Tips
This is just a quick tip on how to get a voltage readout on your KK 2.0 board.
I like using JST connectors as a simple way to get a power feed from my distribution board on my Quad or T-Copter then connect it in to my KK board.
I have been told the extra gound wire is not needed but does not hurt anything to be connected.
I like it for the fact things are just more secure on the board when wiring things up.
In just 5 minutes you too can have a nice voltage alarm on your KK board.
I then mount it in the foam box it ships with double stick tape. Super easy and if something happens can be removed with out much effort.
If your looking to pick up a KK Board check out this nice USA seller and fellow hobbyist on Ebay.
FMICMATT on eBay. His shipping is fast and all items well packed. My KK2s came with the most recent firmware installed too.
Please Subscribe, Like & Comment
Build, Fly, Crash, Repair, Repeat.
Find us on Facebook. https://www.facebook.com/StoneBlueAirlines
iBcrazy on youtube :cagreve1231
My Gear:
FPV Gear:
http://videoaerialsystems.com/
http://hobbywireless.com/
http://onlyflyingmachines.com/
http://www.securitycamera2000.com/
FPV Camera:
Sony CMQ1993X
Video:
808 #16 Keychain Camera modded lens.
808 #16 V2 D Lens
Planes:
iBcrazy Spector EPP
iBcrazy Raven EPP
iBcrazy Spartan 48 EPP Wing
Mini EPP Wing
Flight Test Nut Ball
Quadcopter:
Lotus T380 5.8ghz
DJI F450 KK2.0 V1.5
Scratch built T-Copter KK2.0
Radio: Futaba T7Cap 72mhz
Spectrum Dx6i 2.4ghz
Receiver: Coronal RP6D1 / RP8D1 72mhz
Ground Station:
1.2 Ghz Tx & Rx
Helical & Cross Hair Antenna
5.8Ghz Plug & Play
Viewing:
Vuzix Wrap 920 Goggles
Vuzix Wrap 1200
7" LCD BEV-OFM
DVR:
Hobby Wireless VR1500
Great Stuff on YouTube:
http://www.youtube.com/user/flitetest
http://flitetest.com
http://www.youtube.com/user/experimentalairlines
Flying Wing Calculator
http://fwcg.3dzone.dk/
T- Copter Calculator
http://tinyurl.com/bn2zjs2
Free Flight Sim for PC.
http://www.rcdeskpilot.com
Music:
www.freeplaymusic.com
My Job:
www.stoneblueproductions.com
info@stoneblueproductions.com
Photo-Video-Marketing-Design
Cyberdactyl on May 2, 2013
Thanks for posting the tip. The board's been out for a year, yet many aren't aware they can add the voltage alarm. The only drawback to it is it gives only an overall low V indication, and not an individual cell indication as most balance lead lowV alarms do. But, the truly nice thing is you can vary the alarm trip voltage.
Also a tip for channeling out the foam. Take your soldering iron and lightly stroke the channel you want recessed. And if you want an elaborate pattern on the foam (not necessarily for this card) take baby powder or similar, lightly brush it on the components or protrusions on the card and press down on the foam, it'll leave it's mirror image for you to easily follow with your soldering iron.
Freechip on May 9, 2013
Ground or Negative wire isn't really need since the Negative/Ground common for the entire system unless you are using a receiver pack to power the board.
eluminerRC on May 2, 2013
Thanks for putting my article under related articles! BTW, great vids! ;)
