Finally, this is the last video in this quadcopter build series. This was a big long project for me, but it's done now. I hope this will be helpful to you guys. Now that I'm done building this I will continue with some more interesting and sometimes advanced stuff, so stay tuned.
Tips:
1. Up side of the propeller is one with lettering on it.
2. 8045 - first two numbers are propeller diameter in inches (8" in this case) and second two propeller pitch also measured in inches (4.5").
3. If there is and "R" behind the number (such as 8045R) that means that this is reversed rotation propeller. You need 2x normal and 2x reversed rotation propellers for a quad. Normal are intended for spinning in counter clockwise direction so you have to put them on motors 2. and 4. Reversed propellers must be spinning in clockwise direction so you have to put them on motors 1. and 3.
YOU MUST BALANCE YOU PROPELLERS BEFORE USING THEM!
You need:
Propellers (for a quad you need 2x CW and 2x CCW):
8045 SF Propellers and 8045R SF Propellers
Bearing Oil
Battery strap
Ball and carbon rods from SK450 kit
Enjoy RC as much as I do! :)
Many thanks,
Trevor.
eRC
eRC
eRC
Thanks for sharing the knowledge
