How to setup a delta wing with the OrangeRx V2 Stabilizer unit. This unit has onboard delta mixing, so start off by disabling any delta mixing that you have programmed.
- Rx: Using male-to-male servo wires, hook up the Elevator and Aileron controls from your Rx to the stabilization unit's Ele and Aile ports
- Stabilizer: Plug in your right control surface to Ele and your left control surface to Ail-L (right and left control surfaces as you look at the plane from the nose). Then flip the dip switches to the left for Ail, Ele, and Delta.
- Tx: Reverse your elevator output.
That's it! Hope this helps. Let me know what questions you have.
(I think that this should work for all transmitters, but I am using a Dx7se and can't verify this!)
Keep up the great work!!!!!!!!!!! ;)
