Not your typical F-22 Foamie
by Fly'n-V | August 30, 2013 | (5) Posted in Projects
I saw this product in the local Home Depot and having seen several "pink foam" models on the FliteTest and RC-Groups websites, wondered what one could do with this stuff...  24in X 24in X 1in and virtually the same density of the bigger, thinner pink sheets.
I've been itching to build a F-22 foamie but the winds have been brutal here this summer, cutting into the good days for foamie flying.   I thought this thicker stuff might provide a little better penetration for those windy days.
Used the plans referenced in an earlier FlightTest build video and available on RC-Groups, the link should be in the FT build page.  Referenced at bottom of this page.
The foam was easily cut with a handheld jigsaw and edges/contours shaped with a power palm sander and 80 grit sandpaper.  Go with finer grit for finish work.  The vertical/horizontal stabs are dollar tree (Adams) foamboard.  The verts are two ply for ridgidness.
NOTE-- This pink foam does not handle hi-temp hot glue well,  lo-temp seems to work fine.  Note the areas where the fuse mates with wing...hi-temp glue melted the foam a bit.
Propultion/Electronics Info:
BP Hobbies - A2212/6 motor  2200kv
HobbyKing - 35A ESC
TGS Sport 6X4E prop
OrangeRX R610 RX
Turnigy 9gr Servos x 2
Zippy and Turnigy Nano-Tech 3S 1300mah used
I made a couple of maiden test flights before painting...very pleased!  Tracked like an arrow on rails...the extra weight of the thicker foam definitley helped it handle better in the wind.  Now if the rain will stop...I'll work on posting some flight video.
UPDATE- Here's the video:
As always, I want to thank Chad, Josh and Josh, David and all those folks behind the scenes at FliteTest for sharing ideas and sharing this hobby with the world in their own special FT way!  You guys Rock!
Cheers - Sr12
kenton on September 3, 2013
I had a servo pop off one of my first flights of my F22 also...not because of paint, but i just think that the placement of them would be better if they were inserted into the under side spars a bit. Since then, I have also had one of the control horns come loose, and both times it screamed like a rocket into the ground. I have repaired this plane so many times, but still love flying it!
Rubnorris on September 3, 2013
over 400+ views and 1 comment......Come on guys!
Very cool find and well done on your build, that looks sweet!!
rcspaceflight on September 4, 2013
Great looking plane!
I love how the credits are longer than the clip.
... I still don't know why I haven't built one of these yet. I bought the new Flite Test motor mount for it and everything.
Fly'n-V on September 5, 2013
Thanks for the great comments guys! I'm ready to get it in the air again...a pure blast to fly!
fastfred529 on September 9, 2013
Good looking build. Like the thicker and shaped wings.
Fly'n-V on September 22, 2013
Thanks Fred! Pictures added to show initial shaping.
DaddyMike on September 22, 2013
NICE!! I've printed off the plans but have yet to build one. Am I seeing this wrong or did you sand some airfoil into your wings?
Thanks Mike! Adding some pictures to give you an idea of the shaping...I use a razor for the initial shape then a power sander to finish.
