New E-Flite P-39 Airacobra 1.2m - Scale RC Warbird
by FliteTest | April 9, 2019 | (11) Posted in News
E-Flite recently announced this brand new warbird to their lineup - and it's not a Mustang!
If you're a fan of great looking radio controlled warbirds, you'll probably be pleased to hear that there is a new one on the electric RTF scene. This is E-Flite's latest 1.2m model that bristles with extra features and scale details.
Link to Store
Quick Look Features
  • Detailed scale model
  •  3S and 4S compatible
  • Functional split flaps,  electric retracts and steerable nose wheel
  • 6–channel control
  • 7 factory-installed servos and linkages
  • AS3X and Safe on BNF version
  • Removable drop tank
  • Factory-applied decals
  • Large, magnetically-secured top hatch
  • One-piece wing with hands-free servo/retract connection system
  • EPO construction
  • Fast and easy bolt-together final assembly
In Depth Look
Functionality
The E-Flite P-39 includes retractable landing gear (as you might expect). It also has a steerable nose wheel. The P-39 was unique in WW2 as it was the first single engined fighter aircraft to include a tricycle landing gear arrangement. With this model, you can expect stable and predictable ground handling which differs somewhat to most tail-dragger fighters.
The model also has split flaps. This is where the lower surface of the trailing edge of the wing lowers downward whilst the upper surface stays immobile. It's a nice feature that can really help you bring the aircraft down in one piece.
Aesthetics
With a 1.2m (47.2") wingspan, this isn't a small model by any stretch of the imagination. It does, however, fit into the back of your average car meaning transporting the warbird to your local field won't be a problem. When you get it to the field, though, you'll certainly be turning some heads with the exhaust stack, canopy and camp trim scheme details.
 Power
If you're wanting a more scale type flying experience, you can use a 3s 2200 30c battery for sufficient cruising power. Combined with the motor, this battery can power the 58.5-67oz (1660-1900g) airframe nicely with extremely good climb and some vertical capabilities.
Upping the power to a 4s 2200 will see this thing go a little bananas. You can boost the top speed to near 90mph in a dive. The P-39 is, at this time, the fastest prop warbird in the E-Flite range. A strong rigid EPO fuselage, wings and tail have been specially designed cope with the more extreme velocities and air pressures.
Is It For You?
If you're into unique looking models - probably, yes! With the additional features of the BNF version, you won't really have a problem flying this if you've perhaps flown two other E-Flite models. Thanks to SAFE and AS3X, this would be a great first warbird model. The only thing to be wary of is the speed factor. This aircraft is quick, but thanks to the 3s compatibility, you can tone this down to some extent.
The E-Flite P-39 Airacobra can be flown on a 6ch radio, but you might want to take advantage of something with more channels, perhaps a Spektrum DX8e or a Spektrum DX9 Black Edition. This is because the SAFE Select function requires a 7th channel on your Rx. Having said this, if you don't mind pairing it with another channel, say your flaps, you can still take advantage of the feature. This could be useful for those tricky landings where you really don't wan't to mess up with an avoidable tip stall!
Versions
BNF version, includes SAFE and AS3X $279.99 - https://store.flitetest.com/eflite-p39-airacobra-1.2m-bnf-basic-electric-airplane-1200mm-efl9150/p968606
PNP version, doesn't include SAFE and AS3X (as you have to supply your own receiver) $249.99 - https://store.flitetest.com/eflite-p39-airacobra-1.2m-pnp-electric-airplane-1200mm-efl9175/p968607
If you enjoyed this article, make sure to give it a thumbs up so others can find it too!
Share what you’re working on!
Write an article for Flite Test
Post on the Forums
Share on the Flite Test Fans Facebooks Group
Article by James Whomsley
Editor of FliteTest.com
Contact: james@flitetest.com
YouTube Channel: www.youtube.com/projectairaviation
Gryf on April 14, 2019
Nice-looking model for sure! Wouldn’t it be cool if they located the motor behind the cockpit like the original?
SquirrelTail on April 9, 2019
mandatory purchase. One of my favorite planes.
