My 3rd scratch build
This Build is a simpler build than my first two, they both ended badly.
The whole plane is made from De-pron foam
I know the weight balance is going to be tricky
Any thoughts and suggestions
This is the plane i'm yet to glue on the motor
I'm using KFm2 airfoil with a sanded leading edge. I wanted a big tail so my wish was my command and yes it has Elevons.
Rear View. Large-ish Control Surfaces simple top mounted electro-gubens
And on the Second Day
Today MK.3 grow an extra tail and lost elevons in favor of ailerons and an elevator. the motor was also attached today.
The elevator is attached to the back of the wing plus i added a little wing under the tails, this is for strenght and too see what happens.
I put all the electronics on top of the wing, keeps them nice and cool
The dimentions are as follows
Wingspan 800mm
Cord 200mm
Length ~550mm
Weight <800grams
3cell li-po 2200mA
2200Kv motor
6X4 Prop
