Hello! My name is Fedor, surname is Kuznetsov, I'm from Moscow, Russia. Not very long ago I designed and built quite good FPV carrier, so I want to tell FT visitors about it. In spring I decided to build my first specialized FPV aircraft. At first, I had to choose configuration of my plane. And I thought, that the best variant of the size and configuration is something like "mini talon" pusher. But I decided to use more aerodynamically clear fuselage , medium - mounted wing and classical tail instead of talon's V-tail. In First prototype of my plane I tried to use fully turnable horizontal stabilizer, but it was my mistake. There is one of the first drawings of this model Then, during some free time behind my school exams, I started to build this model. At first, I made paper patterns
The main construction material of this plane is thick and very durable foam-board, which is sold in Leroy Merlin and OBI shops, and usually used for noise insulation and warming in houses. Also I used balsa wood and carbon tubes. This plane was built in several steps. Firstly, using a knife, I cut some details
Then I cut all details, using only knife and abrasive paper. Then, I detached fuselage halves and cut a big volume inside of each other
After that, I installed 3 thick carbon tubes to one of the fuselage's halves. Further I started to make the wing consoles. My mini - tiger helped me :)
At first I cut placements for longerones. Then I cut 12 stripes of balsa, made 5 cm long trays in each other and glued 15 cm long pieces of 3mm thick carbon tube using C.A . Then I glued these "pencils" to the foam segments of the wings using hot glue. At last I attached magnetic fixators to the wing. And the first prototype was ready
First test flight it made on July 8 , in spite of very bad weather. Plane flew well, but it was extremely unstable in pitch channel. I tried to enlarge square of horizontal tail, but plane was very unstable. And in one of the flights plane started to dive and it crashed. After analysis of mistakes, I built the second prototype.
And after all, on August, 12 , it was maiden flight. It flew and glide amazingly and was very stable and easy to fly. Then I tested flight duration. This plane flew over 70 minutes, using 4A•h 3 cell battery (with all FPV setup installed). Also aircraft is very maneuverable and rather fast. And also it can fly on low speed, being very stable and controllable. There are some characteristics of this plane: wingspan - 1280 mm, length - 1100 mm , mass - 700 grams , engine - Impact 2215, battery - Impact 3S 4000 mah. I hope, that you like my aircraft and article. At last, I wish you good flights and landings ! Sorry for my English.And there is flight video:
